Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc..
Old 09-29-2014, 03:09 PM
old_blue1's Avatar
old_blue1
old_blue1 is offline
Just curious, on the jag front end are replacement parts fairly easy to get? Things like springs and ball joints etc?
  #77
Old 09-29-2014, 04:33 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
I have found everything I needed is available other than front springs through Rock Auto, I get all the bushings, joints, and brake parts from there. I am reusing my springs so I have not had to buy front springs but I have seen them for sale online.
  #78
Old 09-30-2014, 04:43 PM
drptop70ss's Avatar
drptop70ss
Time for the frame paint..
Keeping the budget low on the build and I love this paint for frames and suspension parts, very durable. I reduce it with naptha and add enamel hardener as well. No longer available at tractor supply since they changed suppliers, but when it was discontinued I bought a few gallons for around $20 each.
And so the frame is now painted. Front suspension rebuild and chassis assembly will be next.
  #79
Old 09-30-2014, 07:33 PM
Skalywag's Avatar
Skalywag
Skalywag is offline
Dave, you still da man
  #80
Old 09-30-2014, 10:05 PM
drptop70ss's Avatar
drptop70ss
Not sure what to say to that, but hey the check is in the mail
After being questioned on the rigidity of the rear hanger extensions I am going to take a step back and box them like I had originally wanted to. I was not totally convinced they would be ok as is and I appreciate the input which made me take another look at them.
So next week I am going to add a ribbon if steel around the bottom, put a gusset inside between the hanger holes, and maybe box the back, maybe not, still need to be able to access the hanger bolts so boxing may not be an option.
  #81
Old 10-01-2014, 11:48 AM
pweng1's Avatar
pweng1
pweng1 is offline
I really enjoy your posts. Your progress is amazing to me so i need to ask you how many hours a day do you put on the truck. I see you have frame stand are you in a big shop or do you do this for a living?
  #82
Old 10-01-2014, 02:24 PM
drptop70ss's Avatar
drptop70ss
Thanks, I hope this stuff is fun to read, I know I have a lot of fun posting this stuff. I still go back and read build threads I did years ago on other sites just to remind myself what I did!
The rotisserie, like just about everything I own, I bought used. Like most of us I am not loaded with cash so I have to make every dollar stretch the best I can, especially with stuff that is expensive new. It is amazing what can be found for sale used with a little work or can be fabricated with not much money.
This is not my job, just my hobby (really a disease) that I enjoy so I do the work when I want to. Time in the shop depends on the day, work days I may go out there an hour, but normally I only get in the garage on off days.
  #83
Old 10-01-2014, 07:12 PM
Skalywag's Avatar
Skalywag
Skalywag is offline
Lowes is now selling valspar paint, that is the shiniest black paint Ihat I ever used. Some states have restrictions as to how much you can buy. I think in Ohio, penn. and wva. you can only buy it in quarts.
  #84
Old 10-01-2014, 08:32 PM
clintonvillian's Avatar
clintonvillian
clintonvillian is offline
I think the ribbon and gusset will be more than sufficient!
  #85
Old 10-06-2014, 10:19 PM
drptop70ss's Avatar
drptop70ss
2 months into the build!
Reinforced the shackle extensions, ended up doing it a little different than planned. Put 3 backbone pieces of 1/4" plate on each one which tied the flat steel to the lower frame rail, then boxed the frame rail. That way in order for the plate to bend it will have to twist the frame rail as well and I dont see that happening. Or at least I hope not!
Started on the front end rebuild, easiest way to get the control arm bushings is the most fun as well!
Just dont get that burning rubber on your skin, because it does NOT want to come off! Soft scrub is for more than stove tops
  #86
Old 10-07-2014, 09:53 PM
DougofMontana's Avatar
DougofMontana
DougofMontana is offline
Dave, an amazing build thread! I have a question about your Jag IFS. You used a '86 XJS. Is there a series of years that can be used? I'm on the search for the right one to put under my '49 F1. Thanks for any input! Keep up the great work
  #87
Old 10-08-2014, 08:32 AM
drptop70ss's Avatar
drptop70ss
Thanks Doug,
Any XJ6 1987 or earlier (must have round head lights, mid 87 things changed) or any year V12 XJS (up to 1995 I believe was the end of production).
The XJ6 is easier to find cheap around here.
  #88
Old 10-14-2014, 11:58 AM
drptop70ss's Avatar
drptop70ss
I have been slacking
Went to Hershey last week, huge swap meet but unfortunately I saw very little F1 stuff. I bought some new parts from one of the usual catalog vendors but used stuff seemed to be far and few between. I did score a mint 51-52 lower front valence and one center tooth for $40, seller was claiming they were chevy parts, but hey I took them anyway just because I am a nice guy.
Front end rebuild is in progress, mostly done and I rebuilt the calipers yesterday, but now waiting on new rotors which are in transit. I was going to try and save the originals, but after cleaning them up I found rust pits and turning them is about the same money as new.
No pics today, will get some when the front end assembly is complete.
  #89
Old 10-14-2014, 10:45 PM
dmack91's Avatar
dmack91
dmack91 is offline
OK, we will let it slide for now, but you will need to make up for it soon.
  #90
Old 10-15-2014, 08:07 PM
drptop70ss's Avatar
drptop70ss
Ok well I got my rotors, and they look like round flying saucers.
Camera is out in the shop but sort of like this
Quick Reply: Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc..
