Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc..
Old 09-15-2015, 12:58 AM
AXracer's Avatar
AXracer
AXracer is offline
Hudson even made a 3/4T pickup in the late 40s called the Big Boy that was pretty sleek looking right from the factory:
nuff about Hudsons, back to Dave's build already in progress.
  #347
Old 09-15-2015, 05:43 AM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
Hudsons are very cool, but not easy to find a solid one to build around here. This is the pic I had to ID the lights, someone at the HAMB dug it up.
  #348
Old 09-15-2015, 02:13 PM
drptop70ss's Avatar
drptop70ss
Tail lights came out good, but I am going to redo the light sockets. Since they were originally accessed from the trunk the back of the housing is open to the elements. A lot of light gets lost out the back and dirt and water from the rear tires can now get inside the housing. I will be doing them over in a couple weeks, going to take some time away from the garage for a bit.
  #349
Old 09-15-2015, 06:22 PM
AXracer's Avatar
AXracer
AXracer is offline
NOOooo! What will I do for my Dave's updates fix???
I look forward to viewing your progress reports. Whatever is taking you away I'm sure is very important. Do come back soon! We'll be waiting...
  #350
Old 09-15-2015, 08:57 PM
drptop70ss's Avatar
drptop70ss
Time flies here, nobody will miss me lol.. just have a lot of hours at work coming up and some stuff to catch up on before snow flies. Dropped the starter out of the backhoe today, solenoid failed, but had to order it so cant put that back together until next week..also have to swap out the engine on my plow truck soon, spun a rod bearing last year.
So here are a couple preview pics..
Hood has been painted, so that will be going on soon
Token jag IFS picture
And look, some front end assembly going on in between the other stuff!
Thats all I got for awhile!
  #351
Old 09-27-2015, 09:01 PM
drptop70ss's Avatar
drptop70ss
Back in NY..took a week away with the family, took a cruise to Bermuda. Very nice island, but no hot rods and the speed limit everywhere is 35Kmh! Scooters seem to be the major mode of transportation, no way could I live there.
Should get back to updates as I can, but still a ton of work days coming up and stuff to get done before snow.
  #352
Old 09-28-2015, 07:57 PM
drptop70ss's Avatar
drptop70ss
Nose is now assembled other than the hood, put the right side front fender on today with the rubber filler strip and the lower fender piece that fills the open spot at the front of the running board.
Pics will have to wait, forgot the camera today.
  #353
Old 10-06-2015, 07:01 PM
drptop70ss's Avatar
drptop70ss
Small update, not been pushing as hard since winter is on its way, just have to accept that I will not be driving this truck until March or April depending on how spring goes. At least now I can drive it in and out of the shop and do burnouts in the yard
Redid the tail lights. Originals had open bulbs which would of had road dirt and water thrown at them.
Found these cheap universal lamp sockets
Upper socket I just had to weld up the hole to fit the socket, lower I had to make a small tube extension to keep the bulb from hitting the inside of the lens.
Welded up the top hole and changed the lower hole to a smaller hole.
Sealed up the lower hole from the inside of the fender with some butyl strip and now lights are sealed up, so no worries of damage.
Thats all I got for now!
  #354
Old 10-21-2015, 06:31 PM
drptop70ss's Avatar
drptop70ss
Long time no post! Been doing other stuff, hitting the fall swap meets and other things to take up my time. Should get back on the truck soon.
Here are some updated pics from today, had to move the truck out of the shop so I could put some drywall on the ceiling, did one 12x24 bay for now to try and keep heat in that area over the winter.
Truck is already being used as a truck, hauling the parts left to finish the build.
Tail lights
Hood back on and a comparison pic of day 1, looks about the same LOL
Final shifter location, ended up working out fine. Truck #1 plans are still to make a remote shifter but this one will stay as is. The Dakota bench is nice because the center console never moves, just the seats slide forward and back.
Hope to get some more done soon!
  #355
Old 10-21-2015, 06:49 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Dave,
This is like "Highlights Magazine" at the Dr's Office. Can you find the (3) differences in these pictures?
o The Door Handle has disappeared.
o There is a Rat sticking out of the gas tank.
o The rear end is a lot lower.. I'm sure there's more....
Looking good Dave! At least there's no snow on the ground!
Ben in Austin
1950 F1
  #356
Old 10-21-2015, 07:14 PM
pweng1's Avatar
pweng1
pweng1 is offline
Nice work Dave.
  #357
Old 10-21-2015, 08:51 PM
topmoo's Avatar
topmoo
topmoo is offline
Originally Posted by ben73058
Hey Dave,
Ben in Austin
1950 F1
I'll play. No wing windows, no glass, new seats, antenna, wheels and tires.
It does look good, nice work!
  #358
Old 10-21-2015, 09:16 PM
drptop70ss's Avatar
drptop70ss
LOL you guys are funny!
I am to the point of really needing to push myself to finish up, my attention span is around a year, and I am already anxious to get started on a 41 caddy I have sitting in the next bay. Gonna put a jag IFS under it, fuel injection, possibly jag IRS as well. Not going to rotisserie it so should be a quick build, may be able to do most of it over the winter. I love this old stuff.
Truck #1 body parts are supposed to be getting painted over the winter, so assembly can start in the spring.
  #359
Old 10-22-2015, 08:58 PM
drptop70ss's Avatar
drptop70ss
Next low buck upgrade will be the dome light! Picked these up at Hershey for $5 for the three of them, look close enough to an F1 dome light for me. They even have 12v bulbs but no idea what they came from.
  #360
Old 10-26-2015, 07:55 AM
Fordycouv's Avatar
Fordycouv
Fordycouv is offline
Caddy over winter. Whadda ya do in yer spare time?
Quick Reply: Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc..
