1949 F4 V8 to Mercedes diesel build thread
Old 04-08-2017, 06:18 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
I worked on the bed today to get it ready to paint. I noticed that when I rebuilt it a few years ago, I was not aware that the subframe for the hoist was out of square. I worked on that today and test fitted it on the truck. I still have a little work to do, but here are some photos to prove that I did work on it.
Thanks, Mark
  #212
Old 04-08-2017, 06:34 PM
49fordv8f4's Avatar
49fordv8f4
I don't think I ever posted before and after photos of the back panel of my bed. The original was too far gone to save. It also had a couple of added stake pockets for the grain racks. I had a new panel formed and welded it in place. I cut the script out of the old back panel and cut a hole in the new panel with a plasma cutter and welded it in place. I also cut the original stake pockets out of the old panel and installed them in the new one. The bumpers were removed when the hoist was installed in 1950, so I made new ones. I bolted them on with 5/16" grade 8 bolts that I had turned the heads to look like rivets. I painted the insides of the bumpers and behind them before I installed them. I used Loctite 680 on the nuts, so they are permanent. I made the new panel a little deeper than the old one to cover the ends of the subframe. I also made it from 3/16" instead of 1/8".
Thanks, Mark
  #213
Old 04-08-2017, 07:25 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Good looking work as always.
  #214
Old 04-09-2017, 03:57 PM
49fordv8f4's Avatar
49fordv8f4
Thank You, Fred!
Mark
  #215
Old 04-27-2017, 06:29 PM
49fordv8f4's Avatar
49fordv8f4
I picked up my bed from the powder coater today. I also had the nine bed strips, inner fenders, battery box, all the air deflectors, fender braces, bushings for all the hoist pins, fan shroud and radiator frame powder coated as well. I had everything done in hammertone black to cover some of the flaws. They did blow a few small holes in a couple of the bed strips, but I expected that. They are still solid, so the holes shouldn't be an issue. I am very pleased with how everything turned out. I am looking forward to getting it all back on the truck, then I can begin wiring. I will post photos of the truck when I get everything back on.
Thanks, Mark
  #216
Old 04-27-2017, 07:51 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Looks good, Mark. I had a few holes in a couple of my skid strips also. A bit of time with the MIG and all is well.
  #217
Old 04-29-2017, 02:22 AM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
Wow...looks great! Looking forward to seeing with all this stuff installed...
  #218
Old 04-29-2017, 10:28 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Looking good! Nice job on the script, can't tell it wasn't always there!
  #219
Old 05-01-2017, 10:54 AM
49fordv8f4's Avatar
49fordv8f4
Thanks, Guys. I appreciate the kind words. I post more pics when I get it all back on the truck.
Thanks again, Mark
  #220
Old 05-06-2017, 02:01 PM
49fordv8f4's Avatar
49fordv8f4
The bed, inner fenders, radiator frame, fan and fan shroud are back on. Hopefully for good. The bed is not very heavy, three of us picked it up off of the trailer and set it on the truck. It does ride better with the bed on. Adding the oak floor will help even more.
Thanks for looking, Mark
  #221
Old 05-06-2017, 02:15 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
Really looks good, Mark. Coming together. Stu
  #222
Old 05-06-2017, 02:25 PM
topmoo's Avatar
topmoo
topmoo is offline
Very nice, and the install of the Mercedes diesel looks great too.
  #223
Old 05-06-2017, 04:14 PM
49fordv8f4's Avatar
49fordv8f4
The hoist works! It is a little low on oil, as it is not going up quite all of the way.
Mark
  #224
Old 05-07-2017, 05:05 PM
49fordv8f4's Avatar
49fordv8f4
Thank you Stu and Topmoo for the kind words. I do appreciate it.
Mark
  #225
Old 05-11-2017, 04:55 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Looking good, I like the hoist.
Quick Reply: 1949 F4 V8 to Mercedes diesel build thread
