1949 F4 V8 to Mercedes diesel build thread
#351
Thanks! Bob The three lenses that I used in the light bar are actually too small. I had to machine a ring to center them and make them large enough for the snap ring to hold them in place. The right hand bed corner lense doesn't match the rest, but I will use it until, if and when, I find another Cats-Eye brand lense. I am very pleased with how the lights look.
Thanks again, Mark
Thanks again, Mark
#352
#355
I have made a little progress on the truck in the last week. We have been doing some house remodeling, so I haven't had much time to work on it since Christmas. I have the mud flap brackets made and I finished the rear bumper/receiver hitch yesterday. Here are a couple of photos.
The frame of my truck was shortened when the hoist was added in 1950, so I extended the bumper to get the hitch closer to the back of the bed. I used a 2 1/2" receiver tube. I found a NOS Napa tractor headlight at a flea market, so I mounted it for a back up light. When I get my front bumper cleaned up I will paint both bumpers and the mud flap brackets.
Thanks, Mark
Thanks, Mark
#356
Hey Mark. Thanks for the up-date. All the work on your truck looks first rate! When I do work on my truck, I think to myself, "My son, when it's turn, will probably have to do this particular little thing over again because it isn't quite right". I think you do things right the first time!
Jim
PS. My turn signals are working (sort of). There is a little glitch (wouldn't you know) in the switch itself. Both signal lights flash sometimes. There must be some corrosion or something on the inside. When (if) I get brave, I'll take it apart and have a look. In the mean time, I just have to giggle the lever a bit to make it work.
Jim
#357
Thank you for the kind words, Jim. I do my share of rework also. These mud flap brackets are an example. I didn't like the size tube that I used the first time, so I cut it off and remade them. with a different size tube.
I hope you can get your turn signal switch sorted out, that is a really cool looking setup you have there.
Thanks again, Mark
Thanks again, Mark
#359
