first long test ride
Old Aug 6, 2014 | 08:57 AM
Chevy_Eater's Avatar
Chevy_Eater
Originally Posted by Chevy_Eater
Isn't that for a 4:88 rear? Or am I reading that wrong?
Never mind.
Old Aug 6, 2014 | 08:59 AM
Ford F834's Avatar
Ford F834
Yes, sorry, PB giving me fits on my phone, fixed it...
Old Aug 6, 2014 | 09:54 AM
Chevy_Eater
Yep, I think you fixed it before I finished my reply. Two ships colliding in the night.
So, 4:10s @ 70mph in 4th, direct, is 3,100rpm. Hardly screaming, sounds right to me.
Old Aug 6, 2014 | 09:57 AM
Chevy_Eater
Originally Posted by davidwjacob
is my gear ratio on a sticker somewhere in the truck?
--Dave
Your data sticker on the door jamb will have an axle code you can look up and get the ratio. Also, the axle itself will have the ratio stamped on a tag attached to the cover via one of the bolts. Provided no one removed it when servicing the axle.
Old Aug 6, 2014 | 10:42 AM
Red454sedgwick's Avatar
Red454sedgwick
what he said.
Old Aug 6, 2014 | 08:28 PM
3KP's Avatar
3KP
What if the door jam sticker is gone and so is the ratio tag. How would you figure the ratio then? Just Curious since that's my situation?
I'm assuming it's a 4:10 since it's a 1 ton truck.
Old Aug 6, 2014 | 10:46 PM
Red454sedgwick
the gear ration is also stamped on the ring gear if you take the cover off, also you can mark the tire and count the turns of the drive shaft, but I can't seem to get that method to work for me.
I have seen 1 tons with 3.55, but most are 4.10
2009kr
Sep 7, 2021 09:14 PM
Joezilla
Jun 24, 2019 01:59 PM
bdrummonds
Sep 15, 2007 01:15 AM
echerbst
Aug 13, 2004 12:23 AM
