farm truck problems
Old Aug 4, 2014 | 03:28 PM
Evans88's Avatar
Evans88
farm truck problems
first post and first problem. woohoo.
i got a 1988 F250 super cab, 5.8, 2wd, auto.
ive had a hard time getting information on these 2wd models so here i am.
now the problem I'm having... on occasion she slips like no other, throw her in park then back into drive and she'll be good for a bit. also from a dead stop she shakes then grinds to find 2nd.
i checked the fluid, it definitely needs to be replaced but should i bother if my symptoms are asking for a new transmission?
Old Aug 4, 2014 | 03:32 PM
1995F150XLT4x4's Avatar
1995F150XLT4x4
Friends of mine had slipping and grinding transmissions, they both almost entirely fixed their issues by replacing what seemed to be 100,000 mile transmission fluid and filter.
Just a suggestion. Not always the answer.
Old Aug 4, 2014 | 03:33 PM
Crewcabber's Avatar
Crewcabber
New fluid and new filter could clear up your problems.
Old Aug 4, 2014 | 03:35 PM
Truck Guy99's Avatar
Truck Guy99
You likely need to rebuild it but a fluid change would do a lot. All the symptoms you describe tell me it's on it's way out. We once had a truck with identical symptoms except it would grind in 3rd. Does the fluid look burnt? Metal flakes? Thin? What color?
Old Aug 4, 2014 | 03:37 PM
Evans88's Avatar
Evans88
dirty dirty red, burnt and thin, no metal flakes though. might as well do a service and see what happens?
Old Aug 4, 2014 | 03:52 PM
1995F150XLT4x4
Yeah, do a fluid/filter change. New tranny pan gasket too. Nasty color is normal if it hasn't been done for years, and no metal flakes is a plus. When you drop the pan you'll find out if there is any metal shavings on the magnet or if the filter is laying in the pan where it shouldn't be.
Old Aug 4, 2014 | 03:53 PM
Evans88's Avatar
Evans88
so much for my day off. time to get dirty i suppose.
Old Aug 4, 2014 | 05:07 PM
Evans88's Avatar
Evans88
no filters in town so i just flushed 10L and replaced it will some fresh stuff. overall it runs smoother but there is still a massive grind in the first couple gears. so i guess my next and final question would be what transmission should i find for this thing. go with original or is there something better i can replace it with.
Old Aug 5, 2014 | 06:35 AM
Truck Guy99
What's in it now? C6 or E4OD?
Old Aug 5, 2014 | 10:48 AM
Redneckfordf2502002's Avatar
Redneckfordf2502002
I'm pretty sure the E4OD didn't come out till 89. The other option was an AOD.
I am not 100% sure on this suggestion but maybe if you have the C6 the transmission modulator valve. Maybe even the vacuum line to it broke?
Trav
Old Aug 5, 2014 | 11:38 AM
dixie460's Avatar
dixie460
It's been my experience that 100% of the time when an auto trans makes GRINDING sounds, it's done with life.
Yank that sucker out and put in a 5 speed! If not then...
AOD: 4 speed (3+ overdrive). Not the strongest in stock form but can be made better with a good rebuild.
C6: 3 speed, NO overdrive. Pretty tough trans in stock form, and the predecessor to the E4OD/4R100.
You can ID your trans using these links. Look at the trans pan to figure out which one you have.
3 speed transmissions: http://www.fordification.com/tech/im...-transID07.gif
4 speed transmissions: http://www.fordification.com/tech/im...-transID08.gif
Old Aug 5, 2014 | 07:38 PM
Evans88's Avatar
Evans88
she's got the C6. I'm going to have to agree with dixie460 here. i don't know much about trans but i know that they don't grind unless its about to grenade.
Old Aug 12, 2014 | 12:30 PM
Evans88's Avatar
Evans88
i know there are two different c6 for fords big block and small block. ive got the small block 351w in my truck. if i happen to have a c6 from a big block is it possible to switch the guts over from the BB c6 to the SB c6
Old Aug 12, 2014 | 12:34 PM
Redneckfordf2502002
I believe you can but don't quote me on that.
Trav
Old Aug 12, 2014 | 01:59 PM
Evans88's Avatar
Evans88
alright ill look more into it. would a c4 bolt up and keep the stock drive shaft. ive had a hard time finding info on possible swaps. my small block c6 is shot and i have sourced a c6 big block and a small block c4. whats my best option.
