SRS 44
Old Aug 3, 2014 | 08:13 PM
jonesg's Avatar
jonesg
SRS 44
Ford 1995 E350 van, its been off the road for a yr or so, the airbag light flashes 44 , it was flashing before I took it off the road, I had gotten past inspection by pulling the fuse and silencing the buzzer that gets tripped by being naughty.
I pulled the codes and get a 121 which seems to be idle voltage too high or low, out of range? Battery v at idle is 14.47 , engine off is 12.46
but I have a feeling its not talking about the battery regulator.
But theres nothing in the code reader about the airbag code, I was just counting the SRS light flashing on the dash to get the 44.
I replaced the air pump last yr, wondering if its that, could it be an old fault code stored in the memory?
Battery has been disconnected for months.
Does the airbag code not get stored for the code reader?
Old Aug 10, 2014 | 05:40 PM
Fordtech1's Avatar
Fordtech1
Air Bag flashout code 44
RH Frame Rail Front Air Bag Primary Sensor Not Mounted to Vehicle Properly
Old Aug 14, 2014 | 07:18 PM
jonesg's Avatar
jonesg
Thanks, exactly what I needed to know.
hatch_1989
Jun 6, 2007 08:26 PM
slickrock
1997 - 2003 F150
Dec 26, 2006 06:50 PM
woolie74
1983 - 2012 Ranger & B-Series
Apr 7, 2006 08:43 PM
powerpro
1997 - 2003 F150
Jan 26, 2004 11:46 PM
