1994 Explorer Overheating
Old Apr 17, 2002 | 05:31 PM
JonMichael's Avatar
JonMichael
Post 1994 Explorer Overheating
My 1994 Explorer is running hot. Can anyone out there help me to decide the next step in the diagnosis and cure of this problem?
Yesterday while in stop-and-go traffic with the A/C on I saw that the temperature gauge was pinned all the way to the right on the red line. Other than this, there were no symptoms of overheating (no steam, no smoke, no pinging noises). However, the A/C stopped working. I do not know how long the gauge was like that before I noticed it.
The A/C worked again when the car cooled down.
Recent engine work includes a new catalytic converter, oxygen sensor, fuel pump, fuel filter.
The vehicle has 138,000 miles.
Yesterday I searched this forum for advice and learned that one common cause of overheating in Explorers is the fan clutch wearing out.
I drove home from work today with the A/C off, the windows open, and the heat on full blast in 85 degree weather (on a hot day in Pittsburgh). This did bring the temp gauge down--to a level which was still to the right of the "L" in NORMAL--but, at least not in the red zone.
I went to see a mechanic today. He is almost retired, so he doesn't work many hours anymore, but he gives advice.
He looked at it and saw that the fan was cracked in several places. He said that wouldn't cause the problem, but that it would still need to be replaced before it shatters and does more damage. He thought that the truck was not actually overheating, since there were no symptoms of such. He said that perhaps I had a bad temperature sender or a bad temp gauge in the dash.
The top hose of the radiator was quite hot to the touch. There was no fluid leaking onto the ground. I figure that since running the passenger compartment heat brought down the engine temp, this proves that the water pump is working, since it is cycling water through the heat exchanger. Furthermore, since the top hose got hot, this proves that the thermostat is opening, and that water is flowing. So this lead me to two likely culprits: either the fan clutch was not providing enough cooling airflow, or, the radiator is clogged up and not allowing adequate heat exchange.
I went to the FORD dealer. They were surprised to hear that I did not want them to diagnose the problem (for $63), and that I simply wanted them to replace the fan, fan clutch, and temp sender.
I figured this was a safe gamble, since the fan definitely needed replacement anyway, the clutch might as well be replaced while they were in there (on a clutch with 138,000 miles), and, replacing the sender would be cheap. So I was proud that I had saved the $63.
Well--I lost my gamble! They did the above work for $240, and the truck still runs hot, just as before.
The new fan does make more noise, and it does offer more resistance to turning by hand (with the engine off) than the old one did.
So what do I do now?
If I could somehow connect a thermometer to the coolant, I would know once and for all if the car really is running hot, or if it is just that the gauge in the dash is wrong. (Should I rig up a meat thermometer in the circuit, or can a repair shop measure the running temp?)
If I find that it really is running hot, would I then check the radiator to see if it needs to be flushed out or rodded?
Could this still be a thermostat problem even though there is evidence that the water is circulating?
What about the water pump? Could it be the problem even though it is not leaking, and even though water is flowing?
I would appreciate any advice on these matters. Thanks in advance.
-Jon.
Old Apr 17, 2002 | 11:49 PM
PAUL_2's Avatar
PAUL_2
Jon , How many miles on it ? Has the coolant or thermostat ever been replaced ? You would have been farther ahead financially to let a mechanic diagnose the problem , tell you what was found as the problem , give you a price for replacement & have you Ok the repair .
Old Apr 19, 2002 | 09:46 AM
Rockstar's Avatar
Rockstar
Old Apr 26, 2002 | 12:48 PM
JonMichael's Avatar
JonMichael
Hi.
I just thought that I would post the solution to the problem here, just in case someone with a similar problem searches the site for answers in the future:
I had a thermostat put in and that solved it. The truck now runs with the temperature gauge right between the "O" and "R" on "NORMAL."
The mechanic said that the old thermostat was stuck at about 3/4 open. This explains why the top hose did get hot, and why turning on the heat did cool the engine somewhat. Specifically, there was coolant circulating through the system, but just not enough to cool the engine sufficiently.
The air conditioning works fine now, so I guess that the reason it had trouble before was the hot-running engine.
Thanks for your wonderful web site.
Jon.
Old Apr 29, 2002 | 01:59 PM
pearson28's Avatar
pearson28
4wd High
Yes, thanks very much for posting your fix. I'm dropping off my '95 f-150 tonight with very much the same symptoms...funny reading your post was like you were reading my mind as I followed through your flow of logic diagnosing the thermostat. I'll be very curious to see what the dealer finds.
Old May 1, 2002 | 11:27 AM
pearson28's Avatar
pearson28
4wd High
For the record...it was the temp gauge in the dash. Replaced it and temps. are fine. Good to know I wasn't burning up the engine though it did cost me $250 at the dealer to replace it.
orangeford
16
Jul 21, 2015 10:28 AM
Ranman028
Jul 10, 2014 11:19 AM
danamul
Mar 23, 2013 09:10 PM
Philip1991Explorer
Aug 1, 2003 08:30 PM
dpoelstra
15
Nov 4, 2002 07:22 PM
