1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2003 Navigator Air Suspension Pig Tail
Old 12-06-2014, 08:52 AM
risaac928's Avatar
risaac928
risaac928 is offline
Hey guys, someone has had to have this issue before. Please help. I replaced the relay and the Air Pump tested O.K.
I think I know why the pump wont kick in and raise the Navigator. This Blue/Yellow wire is not getting any power and I cant figure out why. I am not sure what this Blue/Yellow wire is for . Can someone chime in and help me out.
Old 12-06-2014, 11:40 AM
alloro's Avatar
alloro
alloro is offline
Received 4,201 Likes on 2,436 Posts
That wire is used by the control module to supply the ground to the relay coil. See the attached PDF.
File Type: pdf
Old 12-31-2014, 09:55 AM
4srfox's Avatar
4srfox
4srfox is offline
reply
My suggestion go coil over. Eliminate all go these costly problems. Example: I replaced the compressor, one month later the front was loosing air, than I purchased new bags. Then still wouldnt work properly I had new issues. Finally I said the He.. with it and purchased new oil overs. Under $300.00 and there a dream. Should have done it long ago. You an sell your existing stuff and probably get back your $. I did!
V8SHO
10-19-2019 02:51 PM
BIGFOOT13
10-26-2018 12:34 PM
nick_ct_203
05-06-2015 10:07 AM
4jrfox
11-08-2014 11:55 AM
5ass
10-13-2005 11:29 AM
Quick Reply: 2003 Navigator Air Suspension Pig Tail
