Code 32 Help
Old Apr 24, 2002 | 05:15 PM
garyda's Avatar
garyda
Post Code 32 Help
I'm getting a code 32 continuous code 1989 F150 302 , does effect how my truck will run.
Thanks
Old May 1, 2002 | 05:20 PM
madman666's Avatar
madman666
Code 32 Help
Code 32 means "EVP voltage below closed limit"
Which means the EGR valve’s position is not acting right.
This may cause your engine to run rough, you may need to clean your EGR, or change the sensor.
Old May 1, 2002 | 05:32 PM
madman666's Avatar
madman666
Code 32 Help
