Replace brake light switch - 1950 F1 panel
Old 07-31-2014, 04:29 PM
jhweigel's Avatar
jhweigel
jhweigel is offline
So it seems like I may have a bad brake light switch. I plan to check the wiring to make sure that it's not a wiring problem first. I see how the switch installs into the MC and that looks very simple. Do I need to bleed the system if I take the switch out? Will I lose brake fluid if I take it out?
I am planning to have the entire brake system checked out by a professional shop to make sure everything s good. I know it needs brake shoes and parking brake adjustment. If the switch changeout is simple, I will do it. If not, I may have the shop do it.
Opinions or recommendations?
Joe
Old 07-31-2014, 04:35 PM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
Its real straight forward to do, but if its going to the shop for a brake rebuild, might as well let them do it, that way if it twists off, its theirs to fix.
Old 07-31-2014, 08:46 PM
Skalywag's Avatar
Skalywag
Skalywag is offline
Thats about the easiest work you'll ever do on your truck, a pair of channel locks and 5 minutes, no you won't need to bleed the brakes and you may lose a few drops of fluid. Have fun!
Old 07-31-2014, 09:06 PM
jhweigel's Avatar
jhweigel
jhweigel is offline
Thanks everyone for responding. I am having fun fixing the things I know how to fix and learning how to fix the rest.
Trying tp post a picture below. Hope it works.
Old 07-31-2014, 09:14 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
That's a sweet looking panel!
Old 07-31-2014, 09:20 PM
jhweigel's Avatar
jhweigel
jhweigel is offline
Thanks John,
It makes everyone look and smile, especially the ladies.
Glad to hear you are feeling better. I have "been there and done that" so I know a lot about it.
Joe
Old 07-31-2014, 11:31 PM
pweng1's Avatar
pweng1
pweng1 is offline
I like that panel. sweet ride you have.
robh84
01-23-2018 07:53 AM
bbacon
08-11-2014 06:53 AM
63' f100
11-25-2011 08:35 AM
EL_Musico
33
10-14-2011 01:32 AM
Jobslob
12-16-2001 08:03 PM
Quick Reply: Replace brake light switch - 1950 F1 panel
