Iron Cross Running Boards group buy thread
Old 07-31-2014, 10:17 AM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
Originally Posted by BigBlkEX
What is the cost? If you get all these ppl in on the deal? I might be in if I know what am spending? Zip 77450
Price updated in first post.
Old 07-31-2014, 10:33 AM
Pele's Avatar
Pele
Pele is offline
How do these Iron Cross running boards attach? Do they go to a Frame/Body mount or do they use the same mounts as the stock units?
Are they stronger than stock?
Old 07-31-2014, 12:45 PM
Apocalypse's Avatar
Apocalypse
Bumping for pricing additions to the first post
Old 07-31-2014, 01:02 PM
Apocalypse's Avatar
Apocalypse
http://www.carid.com/images/iron-cro...structions.pdf
Good Lord yes, just look at them... there is no way these are going anywhere. I would go out on a limb and say you might even be able to use them as a jacking point in an emergency... anyone agree? I think the main issue would be the mounting hardware more than anything though. As long as you are running good nuts and bolts and everything is reinforced well they should hold damn near anything. If I am incorrect though please tell me as ignorance is dangerous.
Old 07-31-2014, 03:33 PM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
And here I am broke in the play money department after buying parts for the 496 BBC I'm building for the Chevelle... ugh. Mark, I feel that you should increase your order number to a quantity of 2 Those are some sweet looking steps.
Unless my maths are wrong, jacking up an 8300lbs truck on running boards that are held on with five measily 5/16 bolts regardless of Grade would prove to be a really, REALLY bad idea. Not to mention they install in the stock body panel and pinchweld, which I doubt would be beefy enough to take the stress and weight and leverage exerted.
Rock sliders (aftermarket) on Jeeps and such can be used as a jack point, but they are designed to take the vehicles weight slamming down on them against a rock, and not just the weight of some fatty getting into their rig. My rock sliders mounted using 10 Gr-8 11/16 bolts on the main feet, and 5 Gr-8 9/16 bolts down the pinchseam. They also had a support bar that ran tight against the rocker panel and under the body to dispersed the weight and impact forces.
Old 07-31-2014, 03:37 PM
mecdac's Avatar
mecdac
mecdac is offline
Exclamation
Okay, done you get the military discount.
Old 07-31-2014, 04:02 PM
Krazee Matt
Outstanding, thanks good buddy
Old 07-31-2014, 10:13 PM
mecdac's Avatar
mecdac
mecdac is offline
What's the number? Yes, I am buying Krazee Matt's also. He is in Houston area.
Old 08-01-2014, 12:05 AM
Apocalypse's Avatar
Apocalypse
I was thinking that these used grade 8 bolts as well and for some reason was thinking that they bolted to the frame, not the pinch welds. I'm sure you could jack from them.... once
So are we up to 30 now? Medcac is buying mine and like 15 others now so what are we up to?
Old 08-01-2014, 12:21 AM
jazz77's Avatar
jazz77
jazz77 is offline
Count me in. I'm assuming I would be able to use my Paypal account?
Ship to 58538
Old 08-01-2014, 12:29 AM
Apocalypse's Avatar
Apocalypse
Yes they do
Old 08-01-2014, 05:42 AM
mecdac's Avatar
mecdac
mecdac is offline
^^^ No Smilies ^^^^^
Uh no, I am paying for two (2) only.
Looks like nine total?
  #28
Old 08-01-2014, 08:00 AM
Pele's Avatar
Pele
Pele is offline
After looking at the instructions above, I agree.
  #29
Old 08-01-2014, 08:37 AM
tsmall07's Avatar
tsmall07
tsmall07 is offline
Definitely not a jack point, but very cool. Not the right time for me right now, however.
  #30
Old 08-01-2014, 10:53 AM
Apocalypse's Avatar
Apocalypse
Mecdac, you are seriously in for 2. Just making sure.
EDIT: Just re-read your previous post again (and paid it actual attention) so I got you down for 2 now What's the zip for the set bound for Houston?
Quick Reply: Iron Cross Running Boards group buy thread
