Sponsored by: Real Truck
stainless studs ?????
Old Jul 30, 2014 | 07:11 AM
smashfoot's Avatar
smashfoot
I am replacing broken exhaust studs on my2002 350 xl not a easy chore but thought I would use stainless studs and nuts. I don't want to do this again this is the second time I have done this. any advise would be helpful, thanks
Old Jul 30, 2014 | 07:16 AM
SuperDutyScaler's Avatar
SuperDutyScaler
buy the ARP stainless studs, they will never rot or break. I should have done this but i just put a set of Dorman replacement studs two years and they look brand new still.....
Old Jul 30, 2014 | 07:27 AM
Irelands child's Avatar
Irelands child
For sure ARP's. You may spend a few bucks more, but will never have to do the job again. You really don't need the stainless with ARP, but they would look nice if you could even see them
Old Jul 30, 2014 | 09:48 AM
dkf's Avatar
dkf
If you can get ARPs they will be stronger than any OE replacements. Rust usually is not as much of an issue as the studs usually end up snapping due to the expansion/contraction from hundreds of heat/cool cycles.
Old Jul 30, 2014 | 10:44 AM
wizkid00104's Avatar
wizkid00104
You can get all sorts of individual ARP studs, nuts, and bolts from Allen's Fasteners. I did a quick check and 16 studs and nuts from them was about 30% cheaper than a full pre-packaged set from Summit Racing. Verify the size you need.
http://www.summitracing.com/parts/ar...view/make/ford
http://www.allensfasteners.com/detai...D=AJ-1.670-12G
http://www.allensfasteners.com/detai...duct_ID=67850A
Old Jul 31, 2014 | 12:22 PM
AAubinoe's Avatar
AAubinoe
ARP STAINLESS 300 INDIVIDUAL STUDS
ARP (COURSE ) STAINLESS 12PT NUTS (AMERICAN)
Thanks for the links, but I though the studs were metric?
Old Jul 31, 2014 | 03:03 PM
smashfoot's Avatar
smashfoot
The studs are metric m8-1.25 x 62mm I searched Allen's and they did not show any. Is dorman just as good.?
Old Jul 31, 2014 | 03:05 PM
wizkid00104
I don't know. I went to Summit's website and found that kit is suppose to work with the 5.4L. Couldn't hurt to call ARP if you really want stainless.
Old Jul 31, 2014 | 03:10 PM
wizkid00104
I think the longer of these would work:
62mm = 2.44"
Overall Length = 2.793"
ARP METRIC STAINLESS 300 INDIVIDUAL STUDS
Overall Length = 2.250"
mrf250 boat man
Mar 25, 2011 07:21 AM
galaxie641
Modular V8 (4.6L, 5.4L)
Nov 5, 2010 11:18 PM
ride_relax
Jul 6, 2010 07:16 PM
88Vmax
Ontario Chapter
Sep 28, 2009 09:12 PM
96f150
Sep 15, 2009 07:27 PM
