1970 F250 4X4 Rebuild
#46
#47
#49
Rear Frame Hanger for Front Spring
JEFFFAFA I am trying to find the Part Number for the Frame mounted hanger for the rear of the Front Spring on a 1970 F250 4X4. I think Green Sales might have some but I need the correct P/N. The drawings I have seen show the number as 5340, but that also shows as the number for the front hanger too. Any help would be great.
#50
67/72 F250...4X4...rear shackle...C7TZ5340B....obsolete....none in any of my locators. BTW, the bushings that fit in them were part number C7TZ5348A. Bunch of them on my locators if you want some n.O.s. rubber. Let me know. If yours are wallared out I'd take 'em to a local machine shop and have them ream and sleeve them.
#51
Thanks for the fast reply and good info as always. The bushings are in OK shape, just dry rotted. I have new Energy Suspension bushings to be installed. I was just thinking if I could find new ones it might be easier than working on these. It looks like I will drill out the rivets and restore the ones I have.
#52
#53
#54
You're welcome. If it were me I'd use one of my wood clamps to slowly press the Poly bushings in. Put some of their special grease on both the "black" POLY bushing and the inner side of the original shell. It will go in there tight and you want to keep as much of that grease in there as possible. Wood clamps are adjustable and open wide and the jaws are kinda long for reach.
Example:
Example:
#55
#56
Was back working in the garage and moved my parts truck and old bed. Started building a welding cart for both the arc and mig welders. Going to try and get a 3G alternator this weekend at the pick and pull. hope to see what is at the yard for other items to be had. Have been looking for a 67 - 72 short bed frame and cab but no luck in the Maryland area.
#59
#60
Well no luck with a 3G alt, all the cars were 2001 and newer and only seemed to have 65amp units. There were no trucks older than 1980 at the pick & pull here. I need to get further out where some of the older yards are and try my luck. Things are busy and the wife and I are heading to Bloomington, MN on the 28 of may to see our son graduate from college. If I have time I will look in that area for some parts as well.
