1956 f100 rearend
Old 08-31-2014, 12:50 PM
Arkyhunter's Avatar
Arkyhunter
Arkyhunter is offline
1956 f100 rearend
Hello every body I have 56 rear end that I need to pull the axles.I have unbolted the flang but they still don't come out. And also it has a tag that has 41/11 is that a 411 ratio.
Thanks
Arkyhunter
Old 08-31-2014, 01:07 PM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
3.73
I should come off
Old 08-31-2014, 01:23 PM
Arkyhunter's Avatar
Arkyhunter
Thanks for your reply.But I forgot to tell its not a 9" it has a back plate.
Old 08-31-2014, 01:54 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is online now
You will need to use a slide hammer to pull the axles out
Old 08-31-2014, 02:12 PM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
Its probably a Dana 44, stock...
Bigwin is correct use a slide hammer or a rim with the nuts flat with the bolt, and jank it
Old 08-31-2014, 03:34 PM
Arkyhunter's Avatar
Arkyhunter
thanks everyone I also have the 56 3 speed tranny & bell housing whats the newest motor that will work.
Thanks
Old 08-31-2014, 04:58 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Thanks
Arkyhunter
That's 47 divided by 11 = 3.73
EDIT. I see this was already answered.
Old 09-01-2014, 02:29 PM
Arkyhunter's Avatar
Arkyhunter
Well I was hoping it was geared lower. I have all the running gear of this 1956 and I'm using it to build a tractor. But the motor was no good.Will a 60- 70 model motor work with the 56 tranny? If theres anyone in Arkansas that need some 223 motor parts your welcome to them. The bock and to pistons are bad but the rest is ok.
thanks
f700
06-14-2018 02:11 AM
airwick51
02-21-2004 02:25 PM
1953Man
11-27-2001 08:09 PM
Quick Reply: 1956 f100 rearend
