Sponsored by: Auxito
Not starting? F150
Old Jul 27, 2014 | 01:09 PM
TBmoen's Avatar
TBmoen
Not starting? F150
I have a 2001 Ford F150 Lariat crew cab. It does not start. I was told it might be the Gem module by my locale mechanic due to possible moisture getting in it. I took it and the fuse panel out looked it over there was no sing of moisture. I put them back in. The truck started up and worked fine for about 3 months. then it wouldn't start again. I replace the GEM module with a used one and it worked for about another month before it acted up again. I took it out and the fuse box again. put them back in and it worked for a couple more weeks. Now It's acting up and not starting again. I took out the Fuse box and GEM module again looked them over and put them back in. Now it won't start at all. So my question is could it be a bad wire or connection instead of the Module? If so what wire? I'm stumped any help would be great.
Thanks.
Old Jul 27, 2014 | 01:33 PM
projectSHO89's Avatar
projectSHO89
It could be a lot of things since 'won't start' is pretty non-specific.
Old Jul 27, 2014 | 01:55 PM
TBmoen's Avatar
TBmoen
The engine cranks over. When it does start it is immediately. when it doesn't it cranks and cranks.
Old Jul 27, 2014 | 03:18 PM
projectSHO89
Okay, it's an intermittent "Cranks but does not fire". That eliminates the starter circuit.
What else? You have to have fuel, air, and spark.
garyd
1997 - 2003 F150
Jul 8, 2017 08:16 PM
smalexander85
Apr 14, 2013 11:56 AM
stackedstroker1
Mar 22, 2009 06:37 PM
bandito20
Mar 25, 2005 06:42 PM
