I was told the truck would be drained of the fluids that were mixing and correctly replaced as well as the new oil filter. Shouldn't be too bad since i myself changed the oil and replaced the oil filter with new stuff (motorcraft only) the day before i dropped it off.
Low fan power, bad hose, leaking oil coolant reservoir... Thus all fluids drained, new hose and reservoir and fan i believe. Dropped it off on a thursday afternoon. Getting it back tuesday evening. Not sure how more power to the fan will be replenished with the repairs they will do.
I sold my 08 F350 with 6.4 last year but put two radiators in it. Second time they replaced reservoir and it held up until I sold it. Not sure what happened after that. Was out of warranty both times so it was expensive problem. I only ran the Motorcraft gold antifreeze that was spec for truck. Good luck with yours.
Ouch! Yeah this one is partially covered with warranty. Total is about $5,500 and i will cover $1,500 of the bill. I usually put some weight on this truck because I use it for hot shot purposes so its gonna take its toll on it.
I never had a radiator fail on mine. Not saying it would not of, but proper maintance and checking those fluids daily if traveling and weekly if at home is important.
When traveling, I just popped the hood during fillups and visually made sure all was ok. Then in the morning checked for proper levels.
I caught a upper hose failure this way in South Carolina.
