Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
brake flaring tool set
Old Jul 10, 2003 | 08:47 PM
jniolon's Avatar
jniolon
old and in the way
my old trusty double flaring tool has finally given up... the knurls in the press will no longer hold the tubing tight ( at least on 3/8 fuel line)...
anyone recommend a good reliable (less than 100 buck) flaring tool kit for 45° double flare brake lines ???
thanks
john
Old Jul 10, 2003 | 09:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
Get a flat piece of 80-120 grit emery cloth and a flat surface, then grind down the face of the bars a little.
Old Jul 10, 2003 | 11:47 PM
angus's Avatar
angus
Ridgid #345 (Home Despot has them). Doesn't come with the double-flare adapters, but the ones you already have should work.
Old Jul 17, 2003 | 01:40 AM
Scooter29's Avatar
Scooter29
Any commercial plumbing supply should be able to set you up. When it comes to brake lines, I would want a new set-up. You can use the old one for simple house plumbing projects that you don't need the double flare. Sorry Torque1st. Good luck....
Old Jul 17, 2003 | 02:14 AM
Torque1st's Avatar
Torque1st
Posting Legend
That's OK, it is an old tool and die makers trick. Works good but obviously can't be done again or things get out of round. The sealing surface is formed by the round dies so they are perfect, -well as good as the tooling was to begin with.
Double flare tools can be purchased at any good tool store or professional auto parts store.
Old Jul 18, 2003 | 09:14 PM
jniolon's Avatar
jniolon
old and in the way
due to having some great friends... I'm now the owner of the following..
actually an appropriated from friends at work...
Imperial Eastman Flaring Kit 1/8" = 1/2"
and
KD portable flaring tool
they both do an excellent job...
I'm a lucky flaring guy !!
john (too cool for bad flares)
Old Jul 18, 2003 | 09:44 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can send one to me... -hehe
Is the IE tool only for single flares? I don't see the dies for the double flares.
I have no idea what brand of double flare tool I have. I bought it at a Carquest parts store and it is on loan to a buddy at the moment.
Old Jul 18, 2003 | 11:10 PM
Scooter29's Avatar
Scooter29
I've got to get me some friends! That's a nice set-up! You can do my brake lines anytime! Talk to you later....
Old Jul 19, 2003 | 05:59 AM
jniolon's Avatar
jniolon
old and in the way
Eric,
the dies came with mine, this is a pic from the internet that I scrounged to show the set...
john
Old Jul 19, 2003 | 06:08 AM
Torque1st's Avatar
Torque1st
Posting Legend
Those double flare tools make a nice hose retaining bead on tubing. All you have to do is run the first part of the flaring operation to put a nice barrel crimp or bulge in the line. This is useful on fuel lines, tranny cooler lines, and power steering return lines.
Old Jul 19, 2003 | 11:32 PM
willowbilly3's Avatar
willowbilly3
Mine is made by K-D and has provided many years of good service.
Old Jul 20, 2003 | 01:24 AM
Mil1ion's Avatar
Mil1ion
That looks like My set J !
Old Jul 30, 2003 | 09:11 PM
dada's Avatar
dada
I just bought the K-D version and it works very well.... I fooled around with a couple of cheaper bar-type models, but found the pressure you need to make the first bubble in double flaring usually pushed the tubing thru the bar... had to start using pliers to tighten the wingnuts.... too much fuss... the K-D mechanism puts direct pressure right on the tube and I experienced no slippage with a normal effort tightening to secure the tubing.... I also found that their tool kept the little seam on the tubing from getting exagerated on the back side of the flange.... first total rear end to proportional valve job and it was very successful... sorry for the long post, but this is something I've just been through
