I'd say it should be find with a 750 Holley double pumper at the drag strip.
If not racing it then better have a regulator on it to tone it down the psi a bit.
orich
What PSI does it need? That pump is preset to a max of 6.
I did order a regulator already though, just in case I needed it.
I saw where you were kicking around using the high out put Holley pump 6.5 to 8 psi.
Most guys end up having flooding troubles if not then but latter not using a regulator with them, plus and a gauge to read it's pressure to adjust it down some.
But some oem stock pumps now days our putting out more then 6 psi at idle
You guys are saying I need a regulator (which is fine because I bought one) because the pump I bought has too high of an output. The pump has a max of 6 PSI output and you say I need a regulator, but if I need 6PSI and I have 6PSI, what do I set the regulator for?
