6.7L Turbo Diesel weight?
Old 07-24-2014, 07:28 PM
F stock owner's Avatar
F stock owner
F stock owner is offline
Disclaimer:
I know nothing about Dodge/Ram trucks. IMO they're ugly. The same grill design is used on what seems like every vehicle they make. That to me makes the trucks look like a soccer mom minivan. I only threw out the Cummins data because my brother-in-law is a die-hard Cummins fanatic and will swear till the day he dies that the 5.9 is the best engine ever made. Also put it out there as a simple point of comparison. I won't comment on Dodge/Ram any more than I did.
Old 07-24-2014, 07:38 PM
F stock owner
Originally Posted by Karl4Cat
13 qts of oil does not weigh 110 lbs.
Don't forget coolant. Last I looked, water was 8 pounds per gallon x 10.28 gallons = 82.2 pounds.
It's actually 8.33lbs/gal. so 85.63lbs
What does 13 quarts of oil weigh? 24lbs maybe? I don't know that answer.
Old 07-24-2014, 07:44 PM
BigF350's Avatar
BigF350
BigF350 is offline
13quarts of oil should weigh about that.
Old 07-25-2014, 09:43 AM
ArtsBest's Avatar
ArtsBest
ArtsBest is offline
Interested to see the new Tundra and its Cummins 5.0L turbo diesel. I'm betting the new exterior style isn't much different but interior-wise I'm sure the truck will look very good???
Old 07-25-2014, 09:46 AM
ArtsBest's Avatar
ArtsBest
ArtsBest is offline
Does one have to change the fuel filter a lot with a diesel such as the 6.7L turbo?
Old 07-25-2014, 10:01 AM
BigF350's Avatar
BigF350
BigF350 is offline
10,000 miles.
Old 07-25-2014, 10:23 AM
F stock owner
My manual says MAXIMUM fuel filter change interval is 22,500 miles. Oil change MAXIMUM is 10,000 but not over 1 year between changes. I change oil every six months or about 5,000 miles and fuel filter every third oil change or about 15,000 miles. That seems to work for me. The message center will advise when to change both oil and fuel filters. Most people change both much more often than what the manual calls for in a manner the works for them. The type of driving you do will influence the change interval. i.e. heavy towing vs. daily driver.
Old 07-25-2014, 10:46 AM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
Japanese trucks are not relevant in conversations surrounding true heavy duty work-horses like our Fords.. Sorry...
Old 07-26-2014, 10:34 AM
ArtsBest's Avatar
ArtsBest
ArtsBest is offline
Agree but I have to give Nissan credit for installing a turbo diesel to a light duty truck.
Old 07-26-2014, 11:01 AM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
Dodge did the same - last year...
2014 Ram 1500 EcoDiesel drive review | Autoweek
Sorry for the thread drift -
A long time ago, I was comparing the Cummins 5.9 to the Navistar 6.9 and found that the two had many complimentary features although neither had all of them.
One thing I was wondering was if the 6.7 uses a non-twist forging process for their crankshafts.. Does anyone know?
I do know that they use the cracked cap connecting rod design which is great in my opinion, although they cannot be rebuilt. I also wonder if they are using PM (powdered metal) in the rod construction..
17 Oaks
6.7L Power Stroke Diesel
09-02-2016 04:44 PM
Realslowww
128
09-08-2015 05:06 PM
ArtsBest
09-01-2009 11:28 AM
Moulder
1999 to 2016 Super Duty
07-13-2007 08:37 PM
parkland
6.4L Power Stroke Diesel
35
11-28-2006 10:15 AM
Quick Reply: 6.7L Turbo Diesel weight?
