Want to change to AT tires
  #31
Old 07-27-2014, 05:38 PM
MCDavis's Avatar
MCDavis
MCDavis is offline
Originally Posted by mpwbw
Very sharp truck. I love that red Cranberry-like color, though I forget what Ford officially calls it.
Ruby Red is the color
  #32
Old 07-27-2014, 11:39 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
You guys are lucky with the 20's, many more A/T tire sizes to select from. With my factory 22's (that i LOVE) i've only been able to find one size of the tire i want in a A/T. I'll be replacing mine next spring because i cant stand the performance tires they put on my limited.
For winter i have chrome steel 17's with Blizzak snow tires, i'll be having TPS sensors installed before they get mounted to the truck, just because i don't want to look at a light.
  #33
Old 07-28-2014, 06:33 AM
sammy77's Avatar
sammy77
sammy77 is offline
This is definitely the best option. Our winters here are so hit or miss lately, I would destroy the Blizzak's with the normal winters, and the majority of the driving I do.
  #34
Old 07-28-2014, 06:40 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
Russ
Nitto and Toyo have sizes in the Terras and O/C AT2s that will fit without a level. You'll have to step up on width though to the 285. Cooper makes the Zeon LTZ in a couple sizes that'll fit also.
  #35
Old 07-28-2014, 12:30 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Originally Posted by MCDavis
Russ
My plan is actually to go with the Cooper Zeon LTZ as i'm a huge Cooper fanboy. I run the Zeon LTZ on my Excursion and i love them. The size i'm planning is the 305/40 22 which should add a little beefier look then the street tires it has now.
Our winters are harsh enough and we do not salt so the roads stay mostly ice/snow covered that blizzaks are known to last 4 seasons with little wear.
  #36
Old 04-13-2017, 05:25 PM
Scratcha's Avatar
Scratcha
Scratcha is offline
Originally Posted by YoGeorge
If you run the numbers, 2 mpg over 50k miles (the lifespan of a set of tires) means you'll spend an extra $1000-1500 on gas (and 4 mpg would be $2-3000). No value judgment here, just numbers.
My problem with 20" wheels on a truck is that the tires do end up looking more like rubber bands stretched over the rims and offer no useful performance gains for a truck unless you consider "bling" as part of performance--I'd prefer 17 or 18" wheels with a taller tire.
George
I agree 100%. I miss the 15" rims with 35's on them.
BigBird74
01-14-2018 11:27 AM
searay5150
2004 - 2008 F150
13
11-06-2011 07:36 AM
51PanelMan
09-21-2011 12:01 PM
fordboy300
02-11-2011 11:57 PM
Larry619
09-24-2000 07:59 PM
Quick Reply: Want to change to AT tires
