Pinion yoke bottoming out on splines preventing any preload
I'm trying to set preload on my sterling 10.25 pinion bearings. I couldn't get the pinion tight enough to establish any preload I tried using my impact after my breaker bar couldn't do it then that didn't work so I tried my 2.5 foot jack handle on the end of the 2 foot breaker bar and it wouldn't budge! So I counted how many threads were exposed took it all out and put it back together with the same amount of threads exposed and the crush sleeve and bearing aren't making contact but the yoke is bottomed out on the splines on the pinion. Is there supposed to be a spacer between the yoke and bearing other than the slinger?
So it appears you have the crush sleeve in the correct position. Perhaps it's not the correct one?
Do you have a pinion shim between the pinion and the rear pinion gear?
It is a very good diagram I have everything where it should be by the diagram. I have it shimmed to proper pinion depth, the crush sleeve was new out of the master install kit and i measured it when I took it out to compare it to the old one and it was only .011" bigger and the old one didn't look crushed just severely worn on the ends like the previous owner had the same problem
Wondering if maybe the yoke isn't the problem, if attempting to reuse the same one it had on it before?, it had been tightened down by the PO in attempt to tighten things up down there to point its stretched out?
Say even if by chance was missing a shim or even two, a couple of thin shims wouldn't ever be enough to make the difference preventing yoke from bottoming out on splines and if it did the yoke wouldn't be tight on the pinion shaft after had been on it that far. Shouldn't really be able to get the yoke down bottomed out on the splines to start with nothing on the shaft but the yoke, should be tight fit and well before getting to that point. Well could but would be rendered useless after doing so.
How much "space" left over are ya talking anyway? Large as in could measure it with a tape? or talking about just a very small fraction... say couple few thousands of an inch?
It was leaving it loose enough that I had about an eighth inch of play. When I started this job the pinion was loose like the nut had backed off which is common from what I've read so I ordered the master install kit off rockauto and inner and outer hub bearings and seals on both sides every single bearing was cooked due to a bad seal. The pinion had about a 1/4 inch of play
