Several questions
Old Jul 23, 2014 | 01:52 PM
Beedub109r's Avatar
Beedub109r
Several questions
I have a 460 4v with 69000 miles. I am bouncing around the idea of a rebuild. What are the best options for semi-performance parts, i.e: Heads and Cam. I know that a better intake and modern 4bbl with headers will help but what are some of the performance mods that you know of?
Second Question:
Of course I have the HD Dana gear in the pumpkins but what about going with a set of newer axles and more highway friendly gears? Would newer super duty axles fit a Highboy? Would the benefit of 3.73, etc gears be worth the investment? I would like the rear discs as well.
Third question:
Does anyone make a kit for the steering mod or do we need to source the parts for ourselves to switch to the newer steering mod?
Fourth and last question: is the 355 a FE motor or is that something different? The 460 is a 355 series correct?
Old Jul 23, 2014 | 03:46 PM
61steven's Avatar
61steven
To give you the best answer we need more information. Like tire size, transmission, and intended use.
1: performance-
460's are capable of quite a lot of power. An easy way to accumulate all(or most) of the parts you need would be to buy a stroker kit. Cam will depend on your usage. Aluminum heads or dove heads will flow better and yield more power. A single plane intake with a properly sized carb will help power. Headers are a necessity with a performance build. A hot coil and ignition module will help things run stronger as well.
2:gears/axles-
This depends greatly on your current setup and intended usage.
blackjack33's Avatar
blackjack33
#4: The 460 is a "385 series"
335 series: 351C, 351C Boss, 351C H.O., 351M and the 400.
385 series: 429, 429CJ, 429 Police, 460 and 460 Police.
Old Jul 23, 2014 | 04:01 PM
Beedub109r's Avatar
Beedub109r
Awesome, thanks
1: performance-
2:gears/axles-
The engine tips were very helpful, Thanks.
As for usage, it will not be a tough working truck. Probably won't leave the pavement very often. I just wonder if switching out the 4:10s for something more efficient wouldn't help? Also the question was really: Is it easier to update the running gear as it is or is it easier to just install newer running gear? My setup is mild, 460 (stock) with C6. I have no idea what my transfer case is.
Old Jul 23, 2014 | 04:02 PM
Beedub109r's Avatar
Beedub109r
That's awesome. Thanks.
Cool info, thanks.
Old Jul 23, 2014 | 04:06 PM
Beedub109r's Avatar
Beedub109r
Also a wierd question-
I kept reading about the Highboys and gas tanks came up. Mine is a Ranger. No tank in the cab but two under the bed. Is that right or normal?
Old Jul 23, 2014 | 05:41 PM
61steven's Avatar
61steven
It is not difficult To swap gears. It's also more cost effective than a new axle. Gear ratios will be recommended by what tire size you plan to run. There are a few charts that will show up on Google for what gears work with what tire size for economy, balance, and power.
The gas tanks sound correct
Old Jul 23, 2014 | 05:50 PM
arctic y block's Avatar
arctic y block
I believe all Hi Boys were divorced transfer case. Is yours like part of the
trans or has a short drive line between them?
Old Jul 24, 2014 | 07:56 AM
Beedub109r's Avatar
Beedub109r
Divorced
The transfer case is divorced. I have the narrower frame and all the other Highboy characteristics.
Old Jul 24, 2014 | 08:41 AM
Beedub109r's Avatar
Beedub109r
Thanks for all the replies and help
So far, I have learned that I have a 385 series motor.
I have learned that there are options for building it up a bit.
It is easier and more cost effective to switch gears than switch axles.
So far what I still have questions about:
Why I don't have a gas tank in the cab like most highboys.
Whether there is a kit to switch the steering to a 78/79.
Thanks in advance for all the info. This forum rocks!
Old Jul 24, 2014 | 09:01 AM
dustyroad's Avatar
dustyroad
Second Question:
Third question:
This site might help in narrowing down what you want to build.
460 Horsepower Chart (revised 1/24/09) - 460 Ford Forum
On the gas tank question I don't know for sure but could it be possible someone swapped beds on your truck and eliminated the cab tank?
Kit: I don't recall seeing anyone posting of one. I believe they take parts from later years.
Old Jul 24, 2014 | 09:20 AM
co425's Avatar
co425
Highboys only came with in cab fuel tanks.
Old Jul 24, 2014 | 10:08 AM
HIO Silver's Avatar
HIO Silver
Visit the tech thread compilation sticky for info on mildly hopping up the 460. A torquey cam, 4V intake, and 650 cfm will garner upwards of 400 hp on about a $1500-$2000 budget.
Old Jul 25, 2014 | 08:46 AM
Beedub109r's Avatar
Beedub109r
LOVE the 460 site!
That 460 Site is Rad!
I am a little weirded out by the gas tank situation. I'll have to call the original owner and see why the tank was moved. Not a big deal, it gets gas the way it is! LOL (And ALOT of it!)
Looking at some cool heads, cam, Intake, headers and carbs for the rig. I just need to find gears.
Old Jul 25, 2014 | 10:27 AM
Beedub109r's Avatar
Beedub109r
Valve cover stickers
Anyone have a good place to find the original OEM valve cover stickers?
