Stacks or back exhaust?
Old 07-22-2014, 08:56 PM
Ranch Rig's Avatar
Ranch Rig
Ranch Rig is offline
Hello everyone,
I've got a friend who runs dual stacks in his 94 F-250. We had a discussion regarding exhaust systems. He favors the stacks, saying it cools EGT by allowing a shorter distance for exhaust to travel. Although I'm not entirely fond of stacks, anyone have any ideas as to whether stacks make a difference? I know the diameter has a lot to do with it, but I'm scratching my head. Is there a performance increase with stacks versus normal back piping?
Old 07-22-2014, 09:03 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Stacks make ZERO difference in EGTs. After all there is only a 3" outlet at the back of the turbo, THAT is the limiting factor
Anything more than a 4" single exult is for looks and sound. It make ZERO performance gains
Old 07-22-2014, 09:48 PM
fordpride's Avatar
fordpride
fordpride is offline
X2^^^^^^^^
I went from stock exhaust to 3" dp 4"exhaust which made a difference. Then went to 3"dp with 5" from the dp with 5" stacks and the only change was sound.
Old 07-22-2014, 09:49 PM
madpogue's Avatar
madpogue
madpogue is offline
Dual exit pipes on any vehicle that, by definition, has single exhaust looks.... compensating. A SINGLE stack, done tastefully, can look right, but the real questions you gotta ask yourself are whether you want a hole in your bed, and whether you want the outlet that close to the cab and its occupants.
Old 07-22-2014, 10:10 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Come on guys you can't tell me this doesn't look totally rad lol
http://www.craigslist.org/about/best...493372708.html
Old 07-22-2014, 10:17 PM
fordpride's Avatar
fordpride
This has to help with EGT's
Old 07-22-2014, 10:27 PM
Ranch Rig's Avatar
Ranch Rig
Alrighty, good information to know. Since I'm not a fan of stacks, it's nice to know I can use my 4" back piping without sacrificing some "magical stack performance booster".
Well, I'm okay with exhaust being that close to my occupants, however I don't like the fact that I'd have to remove a small amount of space in my bed for a stack. I use my truck for hauling heavy supplies, and I figure I'll use the space under the cab and bed that was given to me...
best of craigslist: 1998 honda accord 3.0 v-tech dually
That thing looks down right weird AF. I know stacks are common, but CB whips and the whole dually thing? Nah.
Old 07-23-2014, 07:27 AM
liftnw8z's Avatar
liftnw8z
liftnw8z is offline
(CL) Team Brahma
That's always been why I won't go to stacks. The bed is too useful, especially on a 3/4 or 1 ton, to waste that space.
Old 07-23-2014, 11:59 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
For the love of all that's right in this world, please, no stacks. My 2 cents...
Old 07-23-2014, 12:05 PM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
...unless you do a hood stack! Otherwise, I totally agree.
Old 07-23-2014, 12:19 PM
madpogue's Avatar
madpogue
madpogue is offline
Dude at our local farmers market has a stack setup I like. F-SD C&C with a frame set for a 9-foot bed (the C&Cs have those longer frames), put an 8-foot pickup bed on it, and has a tool box and a stack in the space in between. (Personally, I'd put a fuel tank in there if it were me, but....) Actually a pretty clean looking setup.
Old 07-23-2014, 01:03 PM
BoKnowsDiesel's Avatar
BoKnowsDiesel
BoKnowsDiesel is offline
Former Vendor
It has to be the right stacks on the right truck for it to not look tacky. Very fine line between "That's a sharp truck" and "Man, that guy is trying too hard"
Old 07-23-2014, 01:11 PM
fordpride's Avatar
fordpride
All the really matters is if the person that is putting them on his truck likes them.
I had em on my 97 and they will be going on the dually and cN care less what anyone else thinks.
Old 07-23-2014, 08:05 PM
Gicknordon's Avatar
Gicknordon
Gicknordon is offline
the only ones ive ever liked were ones that the stacks were the main uprights of a head ache rack
Old 07-23-2014, 09:37 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
Stacks provide no performance gains over "normal" exhaust routing, IMHO. Stacks serve a purpose and I have no problems with the folks that run them. I keep a camper shell on my truck bed 99.99% of the time, so stacks are not an option for me.
If you're going to add stacks, do it because you want them. They won't add any performance value to your setup. On a side note, my local truck club has sponsored some "Dyno Day" events. The dynamometer shop personnel are NOT fans of trucks with stacks because they usually aren't setup to run a "stacked" truck on the chassis dyno. The shop is smoked out before the dyno run ends.
Quick Reply: Stacks or back exhaust?
