Change Oxygen Sensor?
Old Jul 21, 2014 | 10:10 AM
Mbizzal's Avatar
Mbizzal
I have a 1996 F250 5.8 that has not had the O2 sensor changed (I think).
The truck has less than 50000 miles and is in perfect shape. BUT, the exhaust smells pretty bad hot or cold. So I don't think the 02 sensor is working correctly. The truck is rated at 8600 lbs so there is no CAT present but about half way down the exhaust there is a junction where the 02 sensor is.
Will a sensor go bad without a CEL?
Will a OBD1 test find a fault with the 02 sensor even if there is no CEL?
Or is it just better to change it anyway just because of the age?
Thanks ahead of time.
Old Jul 21, 2014 | 10:38 AM
rla2005's Avatar
rla2005
That truck left the factory with a converter in place, regardless if it is >=8600 GVW.
Could you elaborate on this statement: "about half way down the exhaust there is a junction where the 02 sensor is." Halfway down where? It should be near the engine.
The F250/350 trucks have a dual y-pipe that ends in a flange where the converter would have attached. There is a small cross-over pipe between them, that is where the O2 bung is mounted.
O2 sensors do deteriorate over time. But we need to have a better idea how your exhaust is configured. A few photos would help a lot.
Old Jul 21, 2014 | 11:46 AM
Mbizzal's Avatar
Mbizzal
"There is a small cross-over pipe between them, that is where the O2 bung is mounted."
That is what I was writing about.
As for the exhaust I am not sure the answer. The owner says the exhaust has not been changed since he bought it. This is/was a one owner truck and I know him pretty well. It was parked in a garage next to the camper he and his wife used a few times a year. Which is why the low miles.
If there were CAT's were would they be placed on the exhaust? There is nothing but the muffler when it comes to the exhaust, from the headers to the end.
Old Jul 21, 2014 | 12:26 PM
rla2005's Avatar
rla2005
There is only one converter on the F250HD/F350 of this vintage.
The H-pipe looks like this:
The converter bolts to the flange on the end of the H-pipe. Hard to say why yours is missing the converter.
Going back your issue, the O2 sensors appears to be located in the factory location. Yes they can deteriorate with age. Yes, OBD-I will report a lean or rich error code. Yes, there can be a stored code without a Check Engine Light on.
Old Jul 21, 2014 | 02:03 PM
Mbizzal's Avatar
Mbizzal
Great, thanks for all the info. The converter is missing for sure. The position of the H-pipe and sensor location look just like the picture. Its strange, there is no sign of cutting or removing anything.
But, if the CAT is missing then I guess the smell would continue even with a new 02 sensor.
Again, thanks for all the help.
dusty_obs
Feb 23, 2018 12:03 PM
frederic
Exhaust Systems
Jan 5, 2010 09:30 AM
Captbo2001
Mar 31, 2005 11:06 PM
Knightmair
1983 - 2012 Ranger & B-Series
Jul 31, 2003 06:43 AM
mccamy63
1978 - 1996 Big Bronco
Feb 17, 2003 11:13 PM
