Spark plug wires
Old May 1, 2002 | 02:07 PM
mayerst's Avatar
mayerst
Post Spark plug wires
Can anyone tell me the right way to test spark plug wires with an voltmeter? Its been some time since I last did it and cant remember the what resistance is acceptable. As always thanks in advance.:-X11
Old May 1, 2002 | 02:18 PM
Ford501's Avatar
Ford501
Spark plug wires
Set your voltmeter to Ohms ( the horseshoe shaped symbol)
place a probe on each end of the plug wire
number should be very close to zero
Old May 1, 2002 | 04:29 PM
DMDCART's Avatar
DMDCART
Spark plug wires
the resistance can be good but the insulation can be breaking down and causeing leakage.
Old May 2, 2002 | 11:20 PM
Redneckerson's Avatar
Redneckerson
Spark plug wires
Keep in mind the best on the market are rated at 150 ohms per foot. I've tested "stock" type wires that had a total resistance reading of over 1000 and they were operating fine. Just a little FYI. Regards.
Old May 3, 2002 | 09:13 AM
mayerst's Avatar
mayerst
Spark plug wires
Just wanted to give you a thanks!!!!!!!! Got a mighty"ha ha" GM with drivablity problem. Go figure!!!!
Tom
Old May 3, 2002 | 11:42 AM
mike460's Avatar
mike460
Spark plug wires
