1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2002 F350 brake systems
Old 07-19-2014, 03:14 PM
Thirdcharm's Avatar
Thirdcharm
Thirdcharm is offline
Left rear locks up when brakes are applied with any real force, stays locked for a few minutes then goes back to normal (so far). Did a brake job and replaced the brake line and caliper, no change. Pedal good initially but pulses and gradually sinks if you hold pressure. No ABS light coming on so I assume no codes? Saw RABS valve was a problem on other year models, but not located on frame rail.... Lines from master cylinder go to a big block in front of left front wheel well in engine compartment, then out and along frame rails..... I don't see anything else that looks like a metering/pro portioning valve, am I missing something or is that it? Help!
storchmj
08-06-2013 05:36 PM
1973dieselhighboy
06-13-2012 04:08 AM
supercab4x4dually
09-16-2009 06:52 AM
termyt00
11-30-2002 09:22 PM
Quick Reply: 2002 F350 brake systems
