Help Steering Valve Nightmare!!
Jul 20, 2014 | 12:53 AM
My ram looks like the illustration 21 section 36 above.
Jul 20, 2014 | 01:03 AM
Just to double check
The Garrison power cylinder is 15 3/8” long
The Bendix power cylinder (which is what you want) is 10 7/8” long
Jul 20, 2014 | 01:08 AM
This is just how this steering repair has been going. Crazy Crazy!!! If it has been like that do you think I can leave it?
Jul 20, 2014 | 01:11 AM
Quote:
Originally Posted by
michellehmcclure
Unfortunately you can't mix them .. If yours is 10 7/8” long your good ..
Jul 20, 2014 | 01:13 AM
Iill ck in the am! I appreciate your help!
Jul 20, 2014 | 01:18 AM
michellehmcclure
Iill ck in the am! I appreciate you help!
What year is the truck ?
Garrison was used '73-'74 up to serial #T80,001
Bendix was used '74-'77 up to serial #Y20,001
Jul 20, 2014 | 01:21 AM
It is a 1977. And I have a picture of the valve before we fixed it. And It looks like the bendix style.
Jul 20, 2014 | 01:27 AM
michellehmcclure
It is a 1977.
So in that case you have a bendix ram (power cylinder) which is exactly what you want with the bendix arm (power valve) you have
unless someone changed it .. Now if we can get your hoses mated up you'll be driving it again soon
Jul 20, 2014 | 01:29 AM
Awesome… So how do I know which side of the ram uses the 1/4 end valve and which side uses the 3/8.
Jul 20, 2014 | 01:32 AM
michellehmcclure
I have two highboy parts trucks with the Bendix system on them I'll look closer in daylight (morning) and let you know ..
Jul 20, 2014 | 01:35 AM
redroad
You Rock!!!
Jul 20, 2014 | 08:59 AM
They're the very same size.
Why are you creating/responding to multiple threads on the very same topic???
You're only confusing the matter more than it needs to be, which is already confusing enough.
Both Rich and myself have given you clear, albeit slightly hard to read, diagrams straight from the parts catalog. The hose routing does not deviate from this, this is fact.
Jul 20, 2014 | 10:02 AM
Corrected pic to show ports on power cylinder
Jul 20, 2014 | 10:22 AM
Redroad, Also show him how the two lines are positioned in the power cylinder (front/back).
The mods are beings dicks and won't let me post pics.
Jul 20, 2014 | 10:51 AM
montana_highboy
Hope this works to clarify ..
