Handle busted on tailgate
Old Jul 19, 2014 | 12:39 PM
demolitioniskey's Avatar
demolitioniskey
New to this forum, but not the car forum world.
Recently picked up an 81 F150 XLT, and bought new replacement tail lights.
However, the tail gate handle is busted and doesn't open the tail gate to get to the final 2 screws to release the light.
Searched the FAQ, read through the tail gate swap thread and did find anything searching through old forums.
Is there a way to manually open or release the tail gate sans handle working?
Thanks all.
Old Jul 19, 2014 | 01:18 PM
JayzDaddy's Avatar
JayzDaddy
There is 2 rods that connect in the handle area. Lift the handle and look in there for them. Clamp a vice grip on each one and pull tword the center. This should disengage the latches. Ill see if i can find a pic of the innards to help you understand.
Old Jul 19, 2014 | 01:20 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Why don't you try removing the cover panel on the inside of the tailgate?
Vise Grips can grab the rods and pull the latch(es) open.
Old Jul 19, 2014 | 01:25 PM
JayzDaddy's Avatar
JayzDaddy
#5 is the rods your looking to grab. #8 is the rocker or roll over bracket that rotates when you lift the handle. This is probably where your problem is. The rods either slipped out or the bracket is broken because its plastic.
Old Jul 19, 2014 | 01:28 PM
JayzDaddy's Avatar
JayzDaddy
Ard i dont think the 80-86 had the access cover. My gate was busted and rusted so i tossed it when i got my truck but i dont recall seeing the panel and im not finding a replacement part until 87.
Old Jul 19, 2014 | 01:30 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sorry for giving bad information.
I would buy the OEM Ford part over the LMC repop.
Old Jul 19, 2014 | 01:33 PM
JayzDaddy's Avatar
JayzDaddy
Oem is usually a better quality but these catalogs can be invaluable for these exploded diagrams.
Old Jul 19, 2014 | 01:43 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have the HiPo master parts CD, but I don't have a working device with optical drive right now...
Gary has his as a searchable pdf filed -on- his machine (i believe)
Old Jul 19, 2014 | 02:20 PM
JayzDaddy's Avatar
JayzDaddy
Im not that tech savvy. But ive played with enough vehicles to have a working knowledge of most of them. With that and these pics i can usually figure out how some things work. The rest? Well im glad i found this group cause yall have taught me ALOT !!
Old Jul 19, 2014 | 02:27 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It's a great resource and has saved me much time and money.
1980-89 Ford 100-500 Series Light Truck Master Parts Catalog CD - HiPo Parts Garage
Old Jul 19, 2014 | 06:01 PM
Franklin2's Avatar
Franklin2
My 89 does have the access panel. Most of the early trucks don't seem to though.
Old Jul 19, 2014 | 09:17 PM
JayzDaddy's Avatar
JayzDaddy
Is that a catalog to that company or a catalog of what they installed on these years truck. $20 aint bad .
Old Jul 19, 2014 | 09:23 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It is a pdf file of the complete Ford parts catalogs of this era.
ALL the drawings, exploded views and parts numbers.
Gary just posted a clutch mechanism and the parts listings (so I know he is viewing it with Foxit)
https://www.ford-trucks.com/forums/s...3&postcount=23
Old Jul 19, 2014 | 09:30 PM
bill06447's Avatar
bill06447
80-86, no access panel. Remove the 3 cap screws that hold the handle in place, and snake the handle down to a point where you can reach the rods with pliers, as previously stated. If the rods are broken, or fell inside, you're going to have to take an old screwdriver or piece of stiff metal and bend it in such a way that you can sneak it between the latch and bedside to push the latch clear of the stop (which I have had to do) ~Bill
Bluegrass F250
Sep 3, 2020 10:45 PM
1320stang
Jul 3, 2016 09:18 PM
1973FordF100
Oct 28, 2008 02:05 PM
cobrar97
May 10, 2008 09:38 PM
79f150
Oct 8, 2005 05:11 PM
