Add A Leaf Springs
Old Jul 17, 2014 | 10:44 PM
darren_palms's Avatar
darren_palms
Add A Leaf Springs
I recently put a 4wd frame and running gear under my 1978 camper special and the 4wd had a 400 but I put my 460 on it. The nose of the pickup is pretty low so I was wondering where and what kind of add a leaf I could get to lift the nose up a bit (2" or so). Thanks.
Old Jul 17, 2014 | 11:27 PM
Jklnhyd's Avatar
Jklnhyd
Best place to start is to stop starting a thread for every thought you have.
It makes it difficult to know where you are or where you are going.
Old Jul 18, 2014 | 12:14 AM
darren_palms
There's no reason to get in a pissing match...I ask few questions on this forum and most of the time people have useful information for me. Instead of me stumbling around the internet I figured someone could point me in a general direction and I could figure it out from there. I need to lift the front of my 78 3/4 ton 4wd pickup about 2" that is using stock leafs and shocks so I figured an add-a-leaf would work but I'm not sure where to look or what to get. All you need to say is "I would try this website" or "you should use this setup" so if you don't have anything useful to suggest just don't say anything...a forum is for frequent questions and answers so have some respect for a guy who converted a 2wd 78 camper special into a 4wd that has a question or two.
Old Jul 18, 2014 | 06:55 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ck out JC Whitney, they had the cheapest add-a leaf (Skyjacker brand?) $80 a few years ago. I got it and used it on my silver 77, cause the 33's were to close to the front fender edge.
It was easier to install once I removed the front springs all together, and used a vice to compress the pack to get the new spring pack center pin/bolt back in and tightened down.
FYI your spring clamps will have to moved back a bit. And since its off great time to replace the bushings? Double ck the fitment for the 2nd link provided. I was quick shopping. lol
http://www.summitracing.com/int/sear...20add-a%20leaf
http://www.summitracing.com/int/part...f724/overview/
Old Jul 18, 2014 | 09:38 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
Do you have a taper leaf spring up front right now?
-Junior
2PupTruck
Oct 12, 2017 11:34 AM
Sayer Lane
May 8, 2010 11:07 AM
78f-150Supercab
Dec 6, 2006 07:49 PM
1967Ford300
May 5, 2006 11:42 AM
jad4
Jun 17, 2005 09:51 PM
