04 EX front a/c cold
Old Jul 17, 2014 | 05:06 PM
02expy's Avatar
02expy
like the title says, the rear a/c is cold but the front is just hot out side air, i have checked the blend door and it is working as it is suppose to, the air gap is .22 so that is good
the suction line is cold, and i had the system recharged when i got it.. going to grab a thermometer today and a set of manifold gauges so i can check some more
any idea's where to start? im thinking plugged front evaporator core
Old Jul 17, 2014 | 07:39 PM
projectSHO89's Avatar
projectSHO89
Check the temp of the lines as they enter/exit the evaporator core. You need to determine which side of the firewall the problem is on.
Old Jul 20, 2014 | 12:46 PM
02expy's Avatar
02expy
I think I figured out my problem, even though my air gap was good at .22 it was slipping at higher rpm 2000-2500.
When I took the clutch off it was full of a greasy grime substance so I cleaned it up and re gapped to .14
and with the compressor working properly my system isn't full
asterof
1997 - 2003 F150
Jul 27, 2018 11:01 PM
wreedZ71
2004 - 2008 F150
Sep 11, 2009 12:25 AM
jinxie
May 19, 2008 12:33 PM
cubman61
Oct 9, 2007 08:17 PM
01silvergt
Apr 25, 2006 10:18 AM
