After searching for the Engine Calibration Code label on my 86 F150 4.9L 4 spd M/T, I found its remains obliterated on the valve cover. So I've spent more than a few minutes poring over the Master Parts List comparing the various Calibration Parts Lists in sections 93A and B. I think I can determine the calibration code based on what EEC module is in the truck. I haven't pulled the module to check the numbers on it yet. Soon.
Anyway, the reason I got interested in the Calibration Codes is to determine component compatibility for a potential DS2 conversion. I want to make sure that the distributor that I might eventually buy will work with the correct carb, EGR valve, etc.
My question is this: What are the precise differences in the various calibrations? Is there a "secret" chart somewhere that lists the differences and their applications? From what I can see in the Master Parts List, there are 4 different calibrations for a 1983 F150 4.9L, 2 w/d, M/T w/AC that is NOT Calif or Canada. What in the world are the differences? Are some of them towing packages and based on different trannies and rear ends?
By the way there are 3 different calibrations that might fit my original 1986 F150 that I could find.
This is what the calibration code "label" looks like:
The decal on the radiator support is the "Emission Control Information label".
The only reference to the calibration numbers (in the Engine/Emissions Diagnosis book) is for setting idle speed on passenger cars and the 4.2L truck with 2150-2V carb. Different adjustment procedures are used depending on the calibration number. However, all 4.9L, 5.0L and 5.8L engines in trucks show the adjustments as the same for all calibration codes (at least in my 1982 manual) - with the only variations in adjustment procedurers being whether Auto or manual trans., with or without A/C, 49 states or not, and carb type. So I see no need for the calibration code in a truck.
Perhaps if you have an ECA (Electronic Control Assembly) or MCU (Microprocessor Control Unit) to replace, the code might be needed.
Country, I looked all over the engine. I'd be surprised if that sticker has survived almost 3 decades of grease and grime.
Jim, I want to know the codes for a couple of reasons: 1) Just curiosity and 2) I'd like to know what the truck started out with so if I do go the DS2 route I'll have a better idea of what's compatible between stock and conversion. I'd also like to know the Cal Codes of the truck I scavenge the parts from for similar reasons.
I've contemplated contacting Ford HQ to see if I can get some info. I have my serious doubts, though. They are in the business of selling new vehicles, not helping keep 30 year old trucks on the road. Nowhere near as much profit in that I would imagine.
