'99 F250 LD 4X4 5.4L Cylinder Head....
Old 07-16-2014, 10:01 PM
John Hancock's Avatar
John Hancock
John Hancock is offline
Hey guys, I have a 1999 F250 LD 4X4 w/ 5.4L and over 220,000 miles.
Problem, engine developed a pin-hole in the driver side cylinder head just under the thermostat housing of the intake manifold and was squirting water into the fan.
Quick fix, was to patch the outside with J.B. Weld Metal. About a year later I had to remove the intake manifold to replace a IM gasket (I also replace the water pump to heater pipe that run thru the "valley")... I then reinforced the "patch" from the inside since I could reach inside with the IM removed. I discovered the wall of the effected water channel was paper thin due to corrosion. This was about 4 years ago.
Just the other day I found coolant under the truck and the "valley" filled with coolant. I thought the water pump to heater pipe went bad again. But I soon found the leak was coming from another hole in the same cylinder head under the thermostat housing.
So my options as I see them are:
1. Replace cylinder head...my concern is the effect of 1 "tight" new head and 1 "loose" old head on the engine.
2. Replace both heads...my concern is if there is corrosion in 1 aluminum head, where else is there corrosion?
3. Crate motor replacement $$$
Any thoughts and/our advise will be greatly appreciated. Can the heads be changed relatively easy while engine is in truck?
Old 07-17-2014, 05:49 AM
Shernius's Avatar
Shernius
Shernius is offline
You did the intake so you know things are tight in there. How long do you plan on keeping the truck?
I would say that one head wouldn't cause a problem but you don't know whether or not the other is corroded as well.
If it is longer term then a crate or rebuilt motor might be the answer since it would require the same if not less effort to swap out than the head. $$$ also comes into play here as well whether you do the work or not.
Old 07-19-2014, 11:56 PM
killacal's Avatar
killacal
killacal is offline
I'd go with option 4) Low Mileage Junkyard motor.
With 220k I'd be hard pressed to put new heads on. I'd rather spend the time and effort putting a low mileage used motor in.
Old 07-20-2014, 09:21 PM
MJE426's Avatar
MJE426
MJE426 is offline
I have the same year and type of truck you do, changing the back plugs and coils was a big enough hassle, if I where to do the heads I would pull the engine and if your pulling it for heads I would get a low mileage junk yard motor.
Old 07-21-2014, 08:39 PM
John Hancock
Thanks guys for the input. I did some research on rebuilt motors but don't know my engine ID. Can anyone tell me where to find the engine ID?
Old 07-22-2014, 08:41 AM
MJE426's Avatar
MJE426
MJE426 is offline
VIN Decoder - Ford Truck Enthusiasts Forums
The Ford Truck 17-Digit Vehicle Identification Number (VIN) Decoder
It's the 8th digit of the Vin number. The first link will decode the whole Vin for you, or you can look it up on the second link.
Sore Knuckles
01-05-2011 09:18 AM
KyleG
General Automotive Discussion
10-14-2008 10:33 PM
wifes65
24
12-17-2006 06:51 AM
sdloe
12-15-2006 04:33 PM
chili97
05-26-2004 10:20 PM
Quick Reply: '99 F250 LD 4X4 5.4L Cylinder Head....
