Newbie question: 6 volt vs. 12 volt system
  #61
Old 07-20-2014, 09:20 AM
fordf348's Avatar
fordf348
fordf348 is offline
I like my generator....how do I polarize it?
  #62
Old 07-20-2014, 09:31 AM
Doc's Avatar
Doc
Doc is online now
With the engine off, at the regulator, remove the field (F) wire and briefly touch it to the batt (B) connection. You should see a small bluish spark. Re-connect the field wire and you're done.
  #63
Old 07-20-2014, 09:46 AM
fordf348's Avatar
fordf348
fordf348 is offline
OK, polarized it, swapped wires, started engine, gauges still working properly.
Thanks for the help Shane
Heading out with the truck for a ride below the Mason/Dixon line
  #64
Old 07-20-2014, 09:49 AM
Jacnat's Avatar
Jacnat
Jacnat is offline
Walk me through what you just did when you have a minute please. What is involved in polarizing?
  #65
Old 07-20-2014, 09:51 AM
Doc's Avatar
Doc
Doc is online now
I posted it above in post #62.
  #66
Old 07-20-2014, 09:52 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Here's a short video on polarizing the generator...
  #67
Old 07-20-2014, 09:53 AM
fordf348's Avatar
fordf348
fordf348 is offline
jacnat, just do what Doc suggests in the post before mine.....permalink 62....takes 10 minutes to find the screwdriver and 1 minute to do the job
  #68
Old 07-20-2014, 03:20 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Voltage meter jumps around a lot but when I rev slightly it moves to charging. I can borrow a 6 volt this weekend and try that. As someone earlier said, I don't think I can trust that PO properly installed this new battery.
Shouldn't that be an ammeter? Unless someone changed the gauges. The back of the gauge has no connections (see picture) rather it picks up on the magnetic field created when the circuit is on. The front of the gauge should say battery. with charge and discharge markings.
What do the rest of the gauges do when the engine is running?
  #69
Old 07-20-2014, 03:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
OP really needs to pull off the coil, voltage regulator, and wiper motor, to determine if there are any voltage markings on them.
There's no ballast resistor, no gauge voltage reducer, just the one 12v light bulb and a 12v battery thrown in to get it sold. I think this is a 6v truck with 2 incorrect parts.
If a 12v truck is desired in the end, then a step-by-step conversion should be done AFTER replacing the bad wiring.
djscottymiami
2015 - 2020 F150
16
01-07-2018 04:24 AM
kbengt
02-02-2012 05:53 PM
CFDLT
1947 and Older Ford Trucks
11-20-2011 08:28 AM
1950ford
11-01-2007 07:17 PM
erinaldi
09-06-2006 01:26 AM
Quick Reply: Newbie question: 6 volt vs. 12 volt system
