460 oil cooler
Old Jul 16, 2014 | 04:30 PM
fifty-two_f1's Avatar
fifty-two_f1
460 oil cooler
What years did ford put oil coolers on the trucks?
Old Jul 16, 2014 | 05:10 PM
daddylee100's Avatar
daddylee100
Subscribed
Old Jul 16, 2014 | 05:41 PM
SoCalAngler's Avatar
SoCalAngler
my 1992 has one
Old Jul 16, 2014 | 07:59 PM
fifty-two_f1
I have an 89 f350 with a 460 (that I am currently away from) and was wondering if it had one?
Old Jul 16, 2014 | 10:10 PM
F350 1990's Avatar
F350 1990
It varies depending on whether you're talking trans or engine..........the concept came from the aviation industry............
Old Jul 16, 2014 | 10:17 PM
F350 1990's Avatar
F350 1990
Unlikely unless someone has plum'd one................
Old Jul 16, 2014 | 10:44 PM
eakermeld's Avatar
eakermeld
My 89 has a remote mount cooler up in front of the radiator, all from the factory.
Old Jul 16, 2014 | 11:04 PM
SoCalAngler
my 1992 460 has a factory engine oil cooler that is attached to block at oil filter port. It is cooled by the radiator coolant running through it.
Old Jul 17, 2014 | 02:14 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
My '88 has a factory oil cooler.
...and trans cooler, and power steering cooler, and A/C condenser, plus the radiator.
I just yanked it all out and trashed it. It's getting a drivetrain swap anyways. Engine is coming out tomorrow!
Old Jul 17, 2014 | 02:32 PM
eakermeld's Avatar
eakermeld
Don't throw that oil cooler stuff away! The guys that have oil-to-coolant coolers that have failed will want it.
Old Jul 17, 2014 | 06:24 PM
ceetwarrior's Avatar
ceetwarrior
Late 80's for sure.. I have a oem oil cooler if anyone wants to buy PM me.
Old Jul 17, 2014 | 08:17 PM
fifty-two_f1
Cool, thanks guys. Im glad mine has one then! Im putting the engine in a 54 f600 so an oil cooler will be ideal for that!
Old Jul 18, 2014 | 03:48 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The only thing 'good' in my system was the adapter on the block. The lines and the cooler in the grille itself was shot. Oil cooler kits are relatively cheap anyways.
Old Jul 18, 2014 | 07:58 PM
eakermeld's Avatar
eakermeld
That adapter IS the most important part to save. All the other stuff is easily replaced by aftermarket parts but that adapter is perfect and nothing else works as good.
Brett7715
Oct 15, 2017 09:51 PM
tbugher62
Ford Truck Parts for Sale
Jun 8, 2015 12:43 PM
mike83f250
Nov 6, 2011 08:52 AM
rhoward
Nov 12, 2009 07:41 PM
mike460
Sep 3, 2002 10:50 PM
