Replacing turbo, what do you recommend?
#31
Thumper4995,
I cannot tell if you have lost any material from the compressor blades, in fact with my eyes I have a harder time than most figuring things out, so I'll ask you some questions.
Has the compressor blades impacted the housing? You'll know by seeing abrasions or witness marks in the housing.
If so can you grab the compressor shaft and attempt to move it in and out (end play) and side to side? If you can move it and touch any part of the housing that is a no-brainer get it replaced as a bearing failure.
If on the other hand you have fan damage without showing implications from the bearing, then ingestion would be suspect and the warantee could be a little more difficult to prove, unless you found what part was missing upstream from turbo that is tied to a defect in the equipment. I would suspect that some pieces of whatever was ingested would be found in the intercooler.
I assume you don't have significant compressor/fan damage or the turbo would have already torn itself to shreds. If it does so, the big pieces will probably get caught in the intercooler (hint - clean this out) but even the smallest pieces of turbo passing through the engine would cause me major distress.
I know I haven't answered any questions for you, but I do share your concern. The Garrett turbo that I replaced was just about to contact the housing due to the early stages of a bearing failure. When I handed the turnbo to the Garrett rep he confirmed my concern and added that it was common for these to turn 100,000 RPM at max throttle and 70,000 is a normal operational value. I don't know the specs on your turbo, but anything turning that fast has my attention.
Good luck and let us know how this is resolved.
#32
Unless it's a funny shadow, I can see the mark on the housing that the wheel has cut into it. If that is the case then that turbo is trashed. I'd find another dealer, or just bite the bullet and buy a replacement. You can get a decent used stock turbo for less than $400.
#33
#34
I concur with others on this. I have seen FOD (Foreign Object Damage) on compressor blades before. Small nicks in the blade tips are not a real concern, but could cause some imbalance in the turbo - leading to premature bearing failure. As someone else stated, reach in there grab the nut. Try to wiggle it back and forth or in and out. If there is any noticable movement, then the bearings are failing. Also if there are marks on the compressor cover, where the compressor wheel has contacted it, then the bearings are shot. FOD is going to be a difficult one to get repaired as waranty. Something got in there past the air cleaner. Unless some stock part of the intake system has failed, I doubt they would cover the turbo.
If they won't replace the turbo under warranty, I'd buy a good used unit. $790 is too much for a "remanufactured" turbo.
#35
#36
I had good luck getting a reman for my Garrett unit. Don't go to the dealer unless you want to double the cost. If it is a garrett unit try www.egarrett.com and use their locator.
Then give that person the garrett number of the turbo and ask if they have a reman unit available and how much...
http://www.egarrett.com/customer_car...tor_lookup.jsp
Good luck
Good luck
#37
I did some digging and found the wonderfull company that took care of my turbo replacement many years ago.
http://www.hatchkirk.com/
FYI - I don't have any association with these people and I'm sharing this only as a courtesy to my fellow FTEs.
#38
Good luck
Good luck
#40
On second thought...
I do appreciate you refreshing my information which is 8 years old.
Have you done a 'Google' search using the Garrett #s off your turbo in hopes of finding it listed on a merchant's website?
If you would forward them to me, I'm willing to poke around a little - but there is no guarantee of success.
#41
#42
There should be a tag attached to the turbo that is a Garrett (not Ford part number), mine was attached to the bearing housing but remember we are working from an event eight years distant.
The point is, if you want to bypass the Ford mark ups, you'll need to locate the manufacturer's assembly/product numbers.
Glad to hear the turbo is good, but I'm sure you are happier ;-)
#43
#44
The point is, if you want to bypass the Ford markups, you'll need to locate the manufacturer's assembly/product numbers and use them in all interactions with garrett suppliers.
When I purchased my replacement turbo from Hatch & Kirk, and asked if they had a turbo for a xxxx they said 'NO'. In other words they had no knowledge of the turbo from an application standpoint. But when I asked them if they had a Garrett xxx-yyyz
they had it in stock.
That is all I am trying to share with you.
