Sponsored by: Innova
How many Cubic Inches??????
Old Jul 10, 2003 | 09:20 AM
VIBR8R's Avatar
VIBR8R
I am planning on building a down firing ported box for a polk 10" 4 ohm sub. Does anyone know off the top of their head how many cubic inches are need for this application. I am going to be putting this in a 96 full size bronco in place of the current center console between the front seats. Any help would be greatly appreciated.
Old Jul 10, 2003 | 09:49 AM
PrPlayboy's Avatar
PrPlayboy
Every speaker will have it's own requirements. Do you know the specs of the speaker? It should give you a range. For ported it will probly be over 1 cf
Old Jul 10, 2003 | 10:32 AM
AlabamaBronco's Avatar
AlabamaBronco
If it is a GNX104 heres the specs:
Impedance 4 ohms
Cone Material Poly-mica
Surround Material Butyl rubber
Sealed Box Volume (cu ft) 0.65
Ported Box Volume (cu ft) 1 - 1.25
Port diameter (inches) 3
Port length (inches) 9
Free-Air No
Dual Voice Coil No
Sensitivity 93dB
Frequency Response 18 - 0.4k Hz
RMS Power Range (Watts) 50-175
Peak Power Handling (Watts) 400
Top Mount Depth (inches) 4 11/16
Bottom Mount Depth (inches) 5 1/16
Cutout Diameter or Length (inches) 9 3/8
Vas (liters) 27.35
Fs (Hz) 39.6
Qts 0.61
Xmax (millimeters) 6.1
Parts Warranty 1 Year
Labor Warranty 1 Year
Hope it helps...
West
mtntop1
Aug 29, 2014 12:39 AM
emayes2000
6.4L Power Stroke Diesel
Sep 2, 2012 03:44 PM
roosterbob
Feb 22, 2009 10:54 PM
bigdaddyII
1997 - 2003 F150
Mar 11, 2005 08:39 PM
84f150guy
Aug 29, 2004 06:33 PM
