Found a little ball in the fuel bowl
Old 07-19-2014, 11:51 PM
nateairman's Avatar
nateairman
nateairman is offline
As the title says. I found a ball in the fuel bowl. The truck has been apart for six months for a bit of work. I removed the fuel bowl to get at a few things. When I removed the filter to refill it a ball came up outside the filter and fell back in to the bottom. I have no idea what or where it came from. A quick glance is all I had. 1/4" diameter or so.
The truck did start up. I have not checked fuel pressure at idle but will tomorrow when I find the gauge.
Old 07-19-2014, 11:55 PM
Chris56ford's Avatar
Chris56ford
Chris56ford is offline
lost
Sounds like the check ball that goes behind the screen in the regulator, is your screen still there?
Old 07-20-2014, 12:02 AM
nateairman's Avatar
nateairman
It seemed to be there. I looked in the side and it seemed to be. I did pull the regulator off to clean the screen. That was out of the truck on the bench. Any one have a pic of the ball and screen combo?
Old 07-20-2014, 12:53 AM
fordpride's Avatar
fordpride
fordpride is offline
Old 07-20-2014, 09:43 AM
nateairman's Avatar
nateairman
Thanks ford pride. It looks like i will be pulling it a part again. Unfortunately the ball does not float and I will have to disassemble the bowl in the truck.
iverger
11-21-2015 08:46 AM
kyle j
05-17-2012 09:22 PM
F250_
24
09-10-2009 02:58 AM
Vinford
27
11-25-2008 11:27 PM
jmbatlanta
15
11-09-2004 04:57 PM
Quick Reply: Found a little ball in the fuel bowl
