Abnormal Temperature Fluctuation
Old Mar 10, 2002 | 05:11 PM
Mike Lewis's Avatar
Mike Lewis
'91 F-150 with 302, A/C, auto, and standard cooling.
I notice that the temp gauge fluctuates between just about the low-end of the scale to between the O and R in "NORMAL". Happens mostly when accelerating from a stop, easy or hard... but also happens when just driving.
Any thoughts as to what is causing this? The truck did not do this when I first bought it (used) at 67,000 miles. Has been doing it since about 72,000 miles. Has 95,000 today.
I have replaced the thermostat and have power flushed/refilled the cooling system.
-Mike
Old Mar 11, 2002 | 11:08 AM
stevieray's Avatar
stevieray
I have a '93 F150cc w/5.0 5spd 4x4 and it does the same thing. It is almost like the thermostat is opening and closing to keep the temp at a constant level. I have never seen this happen in any other vehicle that I have owned. I wonder if it is a bad ground in the temp sender due to rust in the threads. I have had a similar problem with Ford oil pressure sending units. Taking it out and cleaning it and then re-instaling it cured the problem. It is too darned cold out to start messing with my coolant system right now though.
Old Mar 11, 2002 | 12:03 PM
theleetbeagle's Avatar
theleetbeagle
My 96 I6 does the exact same thing. I hooked up my laptop to the ODBII to get a temp reading and at idle (gauge on the "NO" in normal) I was at 200 degrees with a 8 mo. old thermostat.
NJK
Old May 1, 2002 | 10:20 AM
DMDCART's Avatar
DMDCART
i have a simular problem my temperature fluctuates between "o" and "m" constantly while i'm driving and it started after the system was flushed and i'm not sure where to begin. i have a 1995 f150 351.
Old May 1, 2002 | 12:52 PM
Avanti's Avatar
Avanti
It does it on my 89 Bronco II with everthing new radiator,hoses,thermostat including rebuilt engine etc. Same on my 93 Aerostar with new hoses & thermostat & 92 F150 5.0. The 92 F 150 did not due it untill I replaced the water pump & flushed the system. Before it used to sit on N all the time. I think the thermostat was sticking partly open. Not sure what to do????
Old May 1, 2002 | 04:15 PM
DMDCART's Avatar
DMDCART
a friend of mine said he thought the clutch was slipping on the fan but i think it's to consistent to be that.
Old May 2, 2002 | 10:26 PM
towing_joe's Avatar
towing_joe
Hey Dmdcart. I have the same truck as you 95 F-150 351 and mine does the same fluctuation between O and M. Does not make a difference if it is towing a load or just cruising down the highway. I've just come to live with it but now I'm not sure what to think.
Has anyone installed a manual water temp gauage in their truck? This has been on my to do list but I haven't gotten around to it. Anyone have some advice on where to install the sensor for a manual guage? I heard one person on this site installed it in the line leading to the heater core. This makes sense to me, but I could be way off.
Thanks,
Joey
Old May 3, 2002 | 11:50 AM
DMDCART's Avatar
DMDCART
well mine does it wether i'm towing,running down the highway or sitting still....
Old May 3, 2002 | 04:09 PM
brown 4x4's Avatar
brown 4x4
Mine does it too, along with my parents' '95 Taurus and '96 F-150. I didn't think it was a problem.
[font color="green"]1995 F-150 Supercab XLT longbed 4x4 302 M5OD [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old May 5, 2002 | 11:56 AM
stevieray's Avatar
stevieray
My 93 F150 with the 5.0 does it too. When I pull the dipstick to check the engine oil when the motor is hot the dipstick is screamin' hot, at least I think it is. What is the normal temp for this engine to run at? What is the normal thermostat used, 180 or 192? I guess I will have to hook up a mechanical temp guage to find out what the actual temp is.
Old May 5, 2002 | 07:25 PM
mantta's Avatar
mantta
Ford or nothin
1997 - 2003 F150
Oct 3, 2022 06:55 PM
haulingboat
13
Oct 20, 2008 11:53 AM
Donald Rohret
1983 - 2012 Ranger & B-Series
Feb 6, 2005 07:10 AM
grousehunter
Oct 16, 2004 02:05 AM
