Blown Axle
Old Jul 10, 2014 | 12:05 PM
Buggz_14's Avatar
Buggz_14
Blown Axle
Anybody have experience replacing the rear axle or repair the axle on a f150 swb? I blew my axle or something. Drive line spins but it grinds in the pumpkin.
Old Jul 10, 2014 | 02:14 PM
fabmandelux's Avatar
fabmandelux
Need more info.... Year, model , engine size, trans, 4x4, 2x4?
Old Jul 10, 2014 | 09:14 PM
Buggz_14's Avatar
Buggz_14
1978 f150 swb 4x4 351m 4 speed (np435 I think?)
Old Jul 10, 2014 | 09:36 PM
fabmandelux
Which rear end does it have. A 9" ford, or a Dana 60? Are the wheel lugs 5 bolt or 8 bolt?
Old Jul 10, 2014 | 09:44 PM
Buggz_14's Avatar
Buggz_14
5 bolt pretty sure 9"
Old Jul 10, 2014 | 09:47 PM
fabmandelux
I have a few 9" rear ends and third members. I might have a good used one for you. I need to know the ratio to be sure. There should be a small tag on one of the bolts on the front of the differential. It will tell what the ratio is...
Old Jul 10, 2014 | 09:51 PM
Buggz_14's Avatar
Buggz_14
There is no tag.
Old Jul 10, 2014 | 09:53 PM
fabmandelux
Then you'll have to pull the axels and remove the differential. There are numbers on the ring gear that will tell me what the ratio is. Have you pulled it yet?
Old Jul 10, 2014 | 09:58 PM
Buggz_14's Avatar
Buggz_14
I haven't pulled it yet because I only have a bottle jack. Do I have to pull the whole axle out?
Old Jul 10, 2014 | 10:03 PM
fabmandelux
No, but you will have to block up the complete rear end on jack stands and remove the wheels. Once the wheels are removed you will see a large hole in the axel flange. You put a socket through the hole and remove 4 bolts on each side. This will allow you to pull the axels straight out. Then you remove the ring of bolts around the differential. Then you can remove the differential. On the large gear (the ring gear...) will be a series of numbers. In those numbers is the ratio.
Old Jul 10, 2014 | 10:09 PM
Buggz_14's Avatar
Buggz_14
Ok I'm gonna try and see where I get. How much for new third member?
Old Jul 10, 2014 | 10:14 PM
fabmandelux
I don't have a new one, just some used ones. If I have a ratio you can use you can have it for free!
Old Jul 10, 2014 | 10:26 PM
Buggz_14's Avatar
Buggz_14
Awesome!!! I'm tearing it apart now.
Old Jul 11, 2014 | 12:00 AM
Buggz_14's Avatar
Buggz_14
Got it off. Everything looks fine? What numbers you looking for?
Old Jul 11, 2014 | 12:06 AM
Buggz_14's Avatar
Buggz_14
I can get pics tomorrow. My phone is low so no flash I found AL 5A 20 C902 4209A 10x35. That it?
Strokerin
Aug 2, 2006 11:10 AM
RangerTuff05
Oct 6, 2005 12:29 AM
ddetrick78
Jul 14, 2005 02:17 PM
