Matching numbers?
Old Jul 9, 2014 | 01:32 PM
cosmaar1's Avatar
cosmaar1
Matching numbers?
I know with Chevelles, Mustangs, etc, that matching numbers is a big thing. If your body shell, motor, tranny, and rear end all match, you have something special. I was wondering if the same goes with these old pickup trucks. On a 51 ford f1, the only places I have found on the internet with these vin numbers are the tag inside the glove box and by the steering box on the front frame rail. Are there any other places? if I ever decide to sell (which I probably never will), I would like to know if the motor, tranny, and rear end all belong to this truck.
any thoughts?
Old Jul 9, 2014 | 02:01 PM
FortyNiner's Avatar
FortyNiner
There weren't any component numbers to match on the 48-52 trucks. I'm a bit hazy on the start point for the practice. Smarter folk will be along shortly.
Old Jul 9, 2014 | 02:23 PM
teardropty's Avatar
teardropty
There wasn't a "numbers matching" system on the Fords you are asking about. The best you can do is see if the motor, etc. is what would have been used in the year/model. As for resale value, the biggest thing that matters is condition and how complete the truck is. Good luck.
Old Jul 9, 2014 | 02:38 PM
cosmaar1's Avatar
cosmaar1
I appreciate both your answers. I figured there wasn't such a system, but I thought I would ask anyways in case there is something I was missing.
One last question, I found an article that said Ford started using wood panel beds in 1951. My bed is steel. Does this mean that someone swapped out beds? The fenders and everything looks correct, but could I have a unique 51?
Old Jul 9, 2014 | 03:45 PM
52 Merc's Avatar
52 Merc
We would need pictures of what you have to determine originality. You could have the stock 51 box with a steel-added floor covering. Or it could have been swapped with an earlier version. Hard to say for sure what you have without seeing it. Bottom line is, for 1951 you should have a box with smooth steel sides and an exposed wood plank floor.
Old Jul 9, 2014 | 04:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The 48-50's had wood under the steel floor. Can you guess why they eliminated the steel??
Old Jul 9, 2014 | 04:16 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
So we could build tanks, Jeeps and airplanes?
Old Jul 9, 2014 | 09:11 PM
52 Merc's Avatar
52 Merc
Likely because the new bed design was half the money of the earlier version. When you look at the subframe underneath and all the work and materials put into it, the new style was cheap and simple.
Old Jul 12, 2014 | 08:00 PM
cosmaar1's Avatar
cosmaar1
Sorry for taking so long to respond to you but I finally got a chance to take the truck out and get some pictures of it. Please view my album. I think there are only about 8 pictures or so.
Thanks or your help.
Old Jul 12, 2014 | 09:37 PM
FortyNiner's Avatar
FortyNiner
That's not a stock bed. Is the bed attached to the sides? What is underneath?
Old Jul 12, 2014 | 10:16 PM
cosmaar1's Avatar
cosmaar1
From what I can tell, on both sides there is a steel bar about 1 inch wide that has carriage bolts every foot or so. I would say this is how the steel bed is attached. As far as underneath, nothing. It's all steel. That's why I originally thought my bed was stock until I did a little digging and came on here to ask you guys.
Old Jul 13, 2014 | 12:43 AM
51PanelMan's Avatar
51PanelMan
That's the correct bed except that someone installed the ribbed floor. I bet the wood floor was rotted causing this ribbed floor to be installed.
Old Jul 13, 2014 | 07:55 AM
cosmaar1's Avatar
cosmaar1
Well that's good news.
One last question though. Does the sheet metal part of the truck all look correct for the truck (fenders, good, etc)? I've read some different posts that people said they had a particular year of truck and someone swapped different fenders on it. I believe myself everything is correct, but then again I thought the bed was original for the past two years until I was told wrong on here!
Old Jul 13, 2014 | 08:37 AM
FP's Avatar
FP
The interior seats arent original. Do you have the original ones?
Old Jul 13, 2014 | 11:36 AM
cosmaar1's Avatar
cosmaar1
I probably should have stated that's the only thing on the truck I knew wasn't original other than the 12v system I upgraded to in the fall. . I think they might be out of an older mustang.
As far as me having the original ones, no I do not. Honestly I prefer the bucket seats because some day I would like to fabricate a console in the middle of the seats.
