Parking Brake adjustment
Old Apr 30, 2002 | 08:43 PM
RWADE8188's Avatar
RWADE8188
Old May 6, 2002 | 07:12 AM
TallPaul's Avatar
TallPaul
I had the equalizer break on my parking brake. This is the little metal divider that the one cable hooks in one side and the two wheel cables hook into the other side and is located alongside the frame somewhere in front of the rear spring. On the older trucks the single cable hooked into an adjuster bolt, but my '95 dosen't have that. It just hooks right into the equalizer. I can install it OK, but if it needs adjustment, what do I do? Is it inside the brake drum?
INLINE SIX POWER!
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
"Drive a stick young man! There'll be plenty of time for automatics when you're old and unable."
