EGR insufficient flow code showing
Old 09-20-2005, 08:15 AM
davenpt's Avatar
davenpt
davenpt is offline
I am sorry I posted in a wrong format. I am new and am not familiar with all this yet.
I have a 2002 F-150 that is showing a code indicating "EGR insufficient flow". I replaced the EGR valve and cleared the light/code, but the "check engine light" keeps coming back on and code indicates the same problem. Any suggestions on what may be causing the light to keep coming on, even after replacing the EGR valve?
Any help would be appreciated.
Thanks,
Dave
Old 09-20-2005, 08:22 AM
KevinM's Avatar
KevinM
KevinM is offline
What code are you actually getting?
Old 09-20-2005, 08:47 AM
davenpt's Avatar
davenpt
davenpt is offline
Still getting my feet wet on this site. Don't know if my reply got to you ( Kevin ) or not. I sent it personal to you. Let me know, please.
Thanks
Old 09-20-2005, 02:24 PM
ccoram's Avatar
ccoram
ccoram is offline
You have a bad DPFE sensor - if you have a 4.6 you will also need to take off your throttle body and clean out your EGR ports.
Old 09-20-2005, 03:10 PM
davenpt's Avatar
davenpt
davenpt is offline
Thanks much for taking time to respond. I will try to remedy the situation ASAP.
Old 09-20-2005, 05:38 PM
gmiller0737's Avatar
gmiller0737
gmiller0737 is offline
I think ccoram has the correct awnser Ford egr valves rarely fail the most likely cause of PO401 codes is a faulty DPFE sensor (available only from Ford)
Old 09-20-2005, 08:01 PM
ccoram's Avatar
ccoram
ccoram is offline
Actually you can save yourself a lot of money and if you have the big style DPFE Oreillys sells it boxed as a Borg Warner brand for $47.00. Its the new style black plastic and it is a OEM one. Evidently Borg Warner makes the OEM or the other way around. Its even got the FXXX factory Ford number on it.
Old 09-21-2005, 05:26 AM
davenpt's Avatar
davenpt
davenpt is offline
thanks ccoram for the info on the oreilly DPFE. i will check into it.
Old 09-21-2005, 06:01 AM
Clif Jones's Avatar
Clif Jones
Clif Jones is offline
I had the same problem with my ford, and it was the DPFE. Just make sure you reset the computor.
Old 09-21-2005, 03:44 PM
davenpt's Avatar
davenpt
davenpt is offline
thanks to all who were kind enough to take the time to respond to my problem. i replaced the DPFE part and reset the computer. (by disconnecting the negative terminal, for a short while, i was told..) and will see if the "check engine" light comes back on.
thanks again,
dave
Old 09-22-2005, 06:52 AM
davenpt's Avatar
davenpt
davenpt is offline
have a F-250 with a 5.8 auto, 4WD, that when i start it, i get raw gas fumes through the air vents. i also get no power out of it. first thing in the morning, it's starts good, but after that, it takes a lot of cranking before it starts.
any help would be appreciated.
Old 11-04-2005, 10:18 AM
mdp2110's Avatar
mdp2110
mdp2110 is offline
I had the same problem with my 98 Expedition. Last year I replaced the EGR valve, EGR sensor and reset the codes. The light still came back on. Being ignorant I got fed up and took it in to the dealership. $1000 later the check enging light was off. I have to say at this point that they replaced many other things they thought were worn out.
A week before I had to get the inspection done this year the CEL came back on with the same codes, "EGR Flow Insufficient". My friend. I was not going to take it back to the dealership again after last year. I took off the EGR Valve and cleaned it and made sure all the hoses were clear to the EGR sensor. I put it all back together, reset the codes and completed the drive cycle. The light came back on.
I slept on it for a day and looked at all the places the EGR tenticles led. My last resort was to look at the EGR ports that led to the throttle body. I took of the throttle body, for the first time ever and the ports were caked shut with carbon build up. I cleaned them with an old riffle cleaning wire brush, reset the codes and the light has not come back on for a few days now. You may want to try this before buying a new sensor. I would much rather spend the 2 hours it took to clean the ports that lead into the throttle body then to pay the dealership a few hundred dollars to do the same thing.
Only do it if you are confortable with it thought.
Old 11-04-2005, 12:46 PM
FS-150's Avatar
FS-150
FS-150 is offline
Davenpt, I too had the same problem with my 2002. Yours is a 4.6 I take it? Does it have low miles? I had about 40k miles on mine when I got the code. DPFE sensor cured it. Mine was done at the dealership for FREE because the warranty was extended for this part. I thought it was mileage limited, but it may be time limited as well. It is worth a shot if you have low mileage. If this is on a high mileage truck, the EGR ports may need to be cleaned as stated above.
Old 11-04-2005, 03:35 PM
chrisindallas's Avatar
chrisindallas
chrisindallas is offline
I have had this in the past. It was caused by a clogged fuel filter. It tripped the sensors.. Try that first and reset and see if it goes away.
Old 11-04-2005, 06:58 PM
jdwheels's Avatar
jdwheels
jdwheels is offline
DPFE sensor? I am slow, what is that?
Quick Reply: EGR insufficient flow code showing
