Egr plug
Old Jul 7, 2014 | 12:22 PM
MJMETHOW's Avatar
MJMETHOW
Egr plug
On my 03 looking to pull egr valve, but never seen a plug like this. Little worried about to much force and breaking a wire. Any tips?
Thanks Mike
Old Jul 7, 2014 | 04:01 PM
9228.bobcat's Avatar
9228.bobcat
Guess I don't know what you are referring to as a plug. Egr valve comes out hard sometimes. Take a small pry bar and pry it up after unhooking the wire harness from it
Old Jul 7, 2014 | 04:17 PM
Rusty Axlerod's Avatar
Rusty Axlerod
If I understand right you're asking about the electrical connector? Wiring harness/plug has a latch on it. Look closely, when your get it unlocked it comes off easily. Kinda hard to explain online but you can do it with your finger. A small screwdriver might let you pry around on it a bit to find the latch. Just be easy with the screwdriver the latch can be broken easily.
Old Jul 7, 2014 | 05:39 PM
MJMETHOW's Avatar
MJMETHOW
Thanks Rusty,there is two little taps on the sides.I've used a small screw driver and lt starts to come off than stops.I'am one of those guys that something always goes wrong and it cost more or takes more time.
Old Jul 7, 2014 | 06:12 PM
Rusty Axlerod
The two small ones on the side unlatch so you can pull the backshell off the plug. The one you are after faces the rear of the truck. The edge of it is even with where the plastic part ends. If I'm not mistaken it will also come off if you squeeze in the top part of the latch. Sort of a see-saw deal.
Old Jul 7, 2014 | 10:18 PM
04badford's Avatar
04badford
try this pic
6 0L Powerstroke EGR Valve Repair Connector Harness Pigtail 6 0 | eBay
Old Jul 8, 2014 | 11:01 AM
MJMETHOW's Avatar
MJMETHOW
Thanks guys, who would of figured that looking at the two taps on the sides of the plug that there was a release on the back side. Going to be almost 100 today, so I think cleaning the egr valve can wait.
kel1306
Apr 4, 2011 05:37 PM
02GrayPowerStroke
Feb 27, 2010 08:19 PM
fordman16b
Aug 21, 2006 03:02 PM
dpoelstra
Exhaust Systems
Sep 9, 2002 05:46 PM
wildjon300ci
Sep 8, 2002 06:18 PM
