Truck pulls when accelerating
Old Jul 4, 2014 | 03:34 AM
mtndreamn's Avatar
mtndreamn
My 2006 f350 King ranch pulls to one side or the other when I accelerate. Could this be a bad four wheel drive vacuum solenoid. It doesn't seem to do it when the hubs are locked. It tries to pull the truck back and forth across my lane when the hubs aren't locked
Old Jul 4, 2014 | 12:29 PM
BLADE35's Avatar
BLADE35
Bad U-Joint
To Check the U-Joint
Leave Hubs Unlock and in 2wd
Turn wheels Full left and then spin BY HAND with truck in Park the Ujoint and axel each side (Do they spin Smooth?? Should have no PLAY)
Turn wheels Full Rightt and Repeats above process
Do it on Last Time Wheels STRAIGHT Ahead And Spin ujoint-axel again
But could be wrong you will have to check all the Balljoints and tie rods
you can also check them Its Easier for me to Pull the front Tire to check Balljoint but you can pry it while looking when jacked up
Old Jul 5, 2014 | 01:47 AM
mtndreamn's Avatar
mtndreamn
Thank you
I just took it ti BigO and had them checked. They said they were good however the ball joints are a little worn. I still think it's the four wheel vacuum solenoid because it doesn't pull when I let off the accelerator or drive with the hubs locked.
Old Jul 5, 2014 | 08:18 PM
BLADE35's Avatar
BLADE35
so Big O wants a 1200 Bjoint job did they show you
a bad BJ would force you to Have to Herd the Truck to keep straight Constatntly down the road or would be typical fail senereo with tire wear
There expensive so might not hurt to check
As always anythings possible IMO
Old Jul 6, 2014 | 10:28 AM
steelhead2's Avatar
steelhead2
Are you sure your hubs arent trying to lock when you accelerate? Sounds almost like its stuck in 4x4. Crank the wheel all the way to left or right and turn in a tight circle, see if you feel a bucking sensation, if you do theyre locked. Mine did this, and cycling the 4x4 switch fixed it. The vac solenoid was stuck on mine sending vacuum to the hubs all the time. Does it tend to wander into ruts in the road?
Walleye&WhiteTail
Jan 29, 2015 11:29 AM
Brett W 55 Ford
Mar 3, 2012 04:52 PM
Go4shirts
Nov 11, 2011 03:03 PM
nut1605
Feb 21, 2010 05:42 AM
magnet1
2004 - 2008 F150
Nov 17, 2008 06:35 PM
