98 f150 Diagram Request
Old 07-21-2014, 04:16 PM
88-150's Avatar
88-150
88-150 is offline
Hello everyone, I'm here to see if anyone has diagrams for where the fuel filter is, the coils are in the engine compartment, and a steering wheel diagram because mine wobbles. I did attempt to look for one in a hayes when I was at Pep Boys a bit ago and didn't see one. Any help would be appreciated.. 98 F150 4.6L v8 w/auto trans 4wd 3dr
Old 07-22-2014, 06:08 PM
Dr. Dirt's Avatar
Dr. Dirt
Dr. Dirt is offline
the fuel filter should be on the driver side frame rail underneath the truck.
do you want to know the location of the coils in the engine compartment? if so, bank 1 is on the passenger side and bank 2 is on the driver side. bank 1 goes 1, 2, 3, 4 and bank 2 is 5, 6, 7, 8.
Old 07-25-2014, 11:04 PM
88-150's Avatar
88-150
88-150 is offline
In the front where the wires connected to or... but thanks for the filter location. I'm pretty sure I need to have the filter and a coil replaced as the thing chokes out around 55/60 mph.
I took the steering column apart and it looks like the physical steering wheel is loose or broke from it's mount or something. Will replacing the steering wheel fix this? I couldn't get past the hex nut holding the steering wheel in.
-Matt
Old 07-25-2014, 11:39 PM
73fan's Avatar
73fan
73fan is offline
1998 4.6L has only 2 coils, right? One on the front each head?
Sent from Nexus 4. IB AutoGroup
Old 07-26-2014, 12:34 AM
88-150's Avatar
88-150
88-150 is offline
I think so, at least that's what I've been reading around the board... no way to tell.
Old 07-26-2014, 07:00 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Yes. Follow the spark plug wires to find it.
Old 07-26-2014, 11:36 AM
88-150's Avatar
88-150
88-150 is offline
I thought so, still not sure how to test them because they work only part of the time. Still after that steering wheel diagram so I know what's broken and what isn't.
Firefighter 1406
1997-2006 Expedition & Navigator
12-28-2016 08:34 AM
jwford
2004 - 2008 F150
06-11-2011 10:23 AM
natecousineau
03-22-2008 03:31 PM
Quick Reply: 98 f150 Diagram Request
