vacuum line help!!!
Old Jul 2, 2014 | 07:57 PM
1983f150smitty's Avatar
1983f150smitty
vacuum line help!!!
Hello I just brought a 1983 Ford f150. Originally it was a manually. And just swap over to 351w out of 85. With c6 transmission. All the smog stuff has been remove or plug. I just don't no what goes where to get it running. I will attach picture. Appreciate any help. I pick this truck up for 800 buck brand new transmission and low mileage on the engine. Any additional info needed let me no. Thank you
Old Jul 2, 2014 | 08:02 PM
1983f150smitty
Old Jul 2, 2014 | 08:03 PM
1983f150smitty
Old Jul 2, 2014 | 08:05 PM
1983f150smitty
Old Jul 2, 2014 | 08:10 PM
1983f150smitty
Old Jul 2, 2014 | 08:16 PM
1983f150smitty
Old Jul 2, 2014 | 10:26 PM
Gary Lewis's Avatar
Gary Lewis
I'm not sure where to even start there are so many problems. But, you asked about vacuum lines so let's stick to that. You need the following:
  • Power brakes: It normally goes to a vacuum "tree" that screws into the back of the intake manifold.
  • PCV: You should have a large hose going from the back of the carb, usually, to a PCV valve in the rear of the passenger's side valve cover. And, you should also have a hose from the driver's side oil filler cap to a little filter in the air cleaner.
  • Vacuum modulator to tranny: there should be a plastic manifold on the firewall, and it will have a line going to the "tree" just mentioned and another to the transmission's vacuum modulator
  • Vacuum advance: Hopefully your distributor has a vacuum advance unit on it. If so there should be a line from ported vacuum on the carb, meaning a port that has no vacuum at idle but does have vacuum just above idle and all the way up.
  • HVAC: I don't think you have A/C from what I can see in the pics, but if you do there will be another vacuum line from the plastic manifold on the firewall to a tee over by the blower motor. One side of the tee goes to a vacuum reservoir, either a round plastic ball or a can. The other side goes into the cab. But if you don't have A/C you won't have that.
Old Jul 2, 2014 | 10:43 PM
1983f150smitty
Thank you for the info. I no there other issue you can see from the pics. I taking one step at a time. Do you have or anybody have any pics. On how everything should be connected? I not connecting smog stuff back up. Just basic set up to get the truck connected up.
Also the carb is either going to be rebuilt or replace.Thats why it's disconnected in the pics. Thank you for getting back to me. Also I replace duraspark module. Sorry for the questions. Again thanks for the help and info. If there any pics needed to help further more on my issue with vacuum lines? Thanks,
Matt
Old Jul 2, 2014 | 11:52 PM
Rusty_S's Avatar
Rusty_S
Matt
I dont have any photos that shows in detail what you need, but even then it wouldnt help you much as my 302 has the factory autolite 2bbl carb vs an aftermarket holley 4bbl carb.
My 351w which the vacuum hook ups are very simmilar, I have multiple photos of this engine with no aircleaner on but you cant really see the vacuum hose hook ups.
If you can try to find a vacuum/wiring diagram, ford released diagrams for their vehicles in the 70`s and 80`s that showed how the wiring hooked up as well as where vacuum hoses connect between.
Old Jul 3, 2014 | 07:10 AM
1983f150smitty
Ok. Thanks I will see what I can find a diagram.
Old Jul 3, 2014 | 07:21 AM
Gary Lewis's Avatar
Gary Lewis
The diagram might help, but unless it is from a vehicle back before smog stuff it may have so many "extra" things that it will be confusing. At least it is to me.
But later today I can take some pics of how I have Rusty set up, mark them up, and post them - if that would help.
Old Jul 3, 2014 | 08:24 AM
1983f150smitty
That would be awesome. Thank you
Old Jul 3, 2014 | 11:05 AM
Gary Lewis's Avatar
Gary Lewis
Here are several shots of Rusty's underhood area with callouts for the needed vacuum lines. Hopefully they are self-explanatory but if you have questions don't hesitate to ask them.
This first one shows everything you need if you have no smog equipment but do have power brakes, factory air, and a C6 auto. But, not all trucks came with the plastic manifold on the firewall, so if you don't have one you can either get one at a salvage or install a tee or two.
This one shows the HVAC hookup for factory air.
Here's a better look at the vacuum advance hookup. But, this is where an Edelbrock carb has ported vacuum, so if you have a different carb you'll have to figure out what port has no vacuum at idle but vacuum above idle.
And lastly, a look behind the carb showing the PCV valve-to-carb hose and the vacuum tree. Note that not all carbs have the PVC hookup on the back and you may have to use a port in the intake manifold. And not all trucks came with the vacuum tree, although you should be able to get one at the salvage easily.
Old Jul 3, 2014 | 01:16 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't see a kickdown rod on your truck, but you can clearly see it sitting on top of the vacuum booster hose in Gary's pictures.
This is kind of important if you want that C6 to shift like it is supposed to.
Old Jul 3, 2014 | 01:29 PM
Gary Lewis's Avatar
Gary Lewis
Correct. I haven't driven Rusty enough to make it important, but it does up-shift early and, obviously, doesn't downshift.
