1978 - 1996 Big Bronco
steering wheel compatablity
Old Jul 9, 2003 | 03:52 PM
dsickles's Avatar
dsickles
my steering wheel is getting kinda gross and i was wondering if the steering wheels from the newer 150s and expeditions would fit on my 92. thanks in advance.
Old Jul 9, 2003 | 05:49 PM
steve83's Avatar
steve83
Possibly, but they'll have an airbag. You certainly can't go older. Do you have cruise?
Old Jul 9, 2003 | 05:59 PM
dsickles's Avatar
dsickles
ya i have cruise but no airbags. i was thinking of getting the wheel off of a truck that had the bags deployed so that i could just put the cover back on with no bag in there. would that work?
Old Jul 9, 2003 | 06:04 PM
steve83's Avatar
steve83
No. The airbag wheel doesn't use the cover that yours does. You'd have to leave the airbag in it and hope the cruise button connector is the same.
Your best bet is to get a direct-replacement '92-93 non-airbag wheel.
Old Jul 9, 2003 | 06:33 PM
Binkle88XLT's Avatar
Binkle88XLT
Excuse the newbie here, but why is it fully neccessary to not have a air bag? Does the seat sit too close or what?
Old Jul 9, 2003 | 11:44 PM
greystreak92's Avatar
greystreak92
'92's didn't have air bags therefore the deployment system does not exist in the truck. There is no real reason to avoid putting an airbag equipped wheel into them but it will be useless and as Steve mentioned its hit-and-miss as to whether the cruise control connector remained compatible after the airbag was added in later years. And I don't know if anyone has priced those things lately but they're ANYTHING but cheap. A lot of expense (unless you pop one from a boneyard donor truck) just to replace the steering wheel. I have considered reupholstering the wheel in my own '92. Just haven't gotten around to it.
Old Jul 9, 2003 | 11:57 PM
Binkle88XLT
Ah, I see, so there's not anything really troublesome with it execept for the CC risk.
Do you guys just not know anyone that tried to convert a newer wheel, or is it a wheel by wheel guesswork?
Old Jul 10, 2003 | 12:20 AM
bigric's Avatar
bigric
It has been discussed in this forum before, but I do not believe that successful results have ever been posted. If anybody has done this, speak up! Darn airbags... I never thought that it was a good idea to have a controlled explosion in your face while you were busy wrecking your vehicle.
Old Jul 10, 2003 | 12:28 AM
BroncoRoadKill's Avatar
BroncoRoadKill
You could just remove the air bag unit from the steering wheel.
As for the cruise control, the wiring could be figured out and sliced with out using the oem plugs.
Old Jul 10, 2003 | 12:38 AM
Binkle88XLT
Ah, I'm just perusing the idea.
I have an older wheel with a cover on it, but the sonofabitch squeeks when I turn it, any ideas??
Old Jul 10, 2003 | 12:34 PM
Kemicalburns's Avatar
Kemicalburns
have you thought about installing one of those new grant steering wheels that have the 4 buttons in the middle for cruise control and other things you want at the touch of a button. ill try and find the site that sells them. looked really trick i thought.
late
Old Jul 10, 2003 | 12:38 PM
Kemicalburns
heres that link
http://www.grantproducts.com/default.html
Old Jul 12, 2003 | 09:18 AM
bigric's Avatar
bigric
This was solved in the '67-72 forum by Gtex:
"The Expy wheels are 5x135mm bolt pattern."
According to him, it all changed after '96.
Old Jul 12, 2003 | 01:57 PM
steve83's Avatar
steve83
That sounds like you're referring to lug pattern - not steering wheel mounting.
Old Aug 7, 2003 | 10:32 AM
bigric's Avatar
bigric
OK, I took at look at things while at the junkyard on Monday. As we know, the Broncos and corresponding F-series use the cylinder with the two flat sides to mount the steering wheel. The '97+ vehicles use a cylinder with a notch on each side to mount the steering wheel. I didn't bother looking at the wiring after that.
