f350 sending unit
Old Jul 1, 2014 | 08:55 AM
ptut42's Avatar
ptut42
f350 sending unit
ok so i have a 1994 f350 and was wondering how hard it is to do the sending units in the tank, i know on some trucks it is easier to remove bed than drop tank, the truck has 315k miles on it and front tank guage stopped reading so figured time to replace all of that along with selector and fuel line to fuel pump i am running an air dog fuel pump so from there to motor is all new. thank you in advance love this forum and all the help
Old Jul 1, 2014 | 09:03 AM
ptut42's Avatar
ptut42
forgot to mention front tank gets about 25-30psi of fuel pressure and rear tank gets about 20-15
Old Jul 2, 2014 | 08:28 AM
ptut42's Avatar
ptut42
almost 90 views and no input im kinda sad haha but really need some help here
Old Jul 2, 2014 | 08:50 AM
Holmesuser01's Avatar
Holmesuser01
Well, you already have it figured out.
I guess the aftermarket pump you are running is a reason for no replies.
The tank gauge sender is attached to the electric pump in the tank. You may as well replace both of them at the same time... same goes for the rear tank.
As for pulling the bed... I've never seen a bed pulled for tank work on any of my personal trucks... I'm on my 4th F-series truck, and will never go with another brand, NEVER!
My current truck has a bad gauge sender in the front tank. It also has low pressure at the engine, compared to the rear tank, which had lower pressure at first, but after several tanks being run through it, has come up to normal pressures. I'm pretty sure the previous owner, who bought it new, never ran the back tank very much, judging by the bonked spots around the filler opening where someone bonked the truck with the filler nozzle.
I'm going to leave the front tank empty for now, and get the pump and sender. I've got the plastic tank (!) and will change out the pump this fall when it's cooler outside.
Old Jul 2, 2014 | 09:50 AM
Crewcabber's Avatar
Crewcabber
If IIRC you have a Fummins. You might have better luck in the diesel sections.
Old Jul 2, 2014 | 11:36 AM
ptut42's Avatar
ptut42
thank yall for the replies ya it is a fummins have tried in other forums guess i shouldnt have mentioned the fuel pump but i think im going to pull the bed and redo all the lines and sending units while bed is off ospho it and paint it thank you again for the replies
F460bigbore
Aug 25, 2018 10:04 PM
BigSix1
Aug 17, 2014 07:13 PM
cbr600f31997
Apr 14, 2014 04:41 PM
altruego
May 6, 2008 03:37 PM
richborru
Aug 15, 2007 09:35 PM
