That truck I got didn't have a dome light in it when I got it. All's that's left is the little connector thingy and the screws that held the original in place.
I'm wanting to install the dome light/reading light combo out of an '89 Taurus into the truck, and I was wondering how I'd go about doing this.
I've used a test light, and I'm not getting it to light when I connect one to the connector and connect the other contact to the body. Could I be missing a wire, or were these lights a positive wire with a negative chassis ground or vice versa?
I'm not familiar with the old trucks or the Taurus, but do either of them look like the black plastic ones in this pic? I'd suspect that it would be pretty easy to pick up the dome harness from an '80-96 F-series in a junkyard & put it in, but if you didn't want to fight the little screw terminals, you could use the plug that late Mustangs (for example) use to connect to the same lamp. They have a plastic insulator to keep the mounting screws from making contact, like the trucks' screws do.
